After thinking about this some more, i don't think Tesla would deviate from good design principles, in particular "Form Follows Function".
So if the truck looks Cyberpunk there is a reason for that...
I see a parallel with the Tesla semi, it looks different to a regular semi but has impressive performance, a lot of that performance is down to the design which in turn dictated the aesthetics...
The reason I am confident is the 50K price tag, if that is true the criteria are:-
- Strong
- Lightweight
- Streamlined.
- Efficient
- High load carrying capacity.
- Cheap (50K - for what it does)
I think the 50K price tag limits the size of the battery in the base model to probably no more than 100-125kW
For the truck body the criteria are probably:- Lightweight/Strong/Cheap...
To hit the criteria, perhaps it has to look different...
The combination of strong and lightweight isn't easy to hit, but lightweight helps with cheap...
It could be that some of the strength of the truck and a lot of the efficiency of the truck, comes from the shape of the truck....
That shape might not be a shape you would design, if you didn't have these criteria...
So Elon may be preparing us for something that looks different, the semi looked different, but the specs sold it, not many questioned the design, once they saw the specs...
Truck buyers are conservative, perhaps even great specs and good functional design for a very good price will not sway them,,,
But something that looks more conventional may cost more and not be as functional...
So my thoughts are a higher end model with a bigger battery pack and a higher price tag could look less Cyberpunk...
