My opinion is that RWD is the affordable option, dual rear motors are a cost increase without advantage to a daily driver.
Dynamic torque vectoring is a plus, but not needed at typical driving levels.
Not needed for typical driving.
Packaging constraints are dominant here, and there is no need for dual front motors (assuming the single motor can output sufficient power).
Definitely true, but when are the limits of a single motor reached? What pack size is need to feed the dual under those conditions?
The rear differential is not inefficient. Unless the car is turning, the entire assembly moves as one piece, so the only impacts are inertia and lubricant slosh.This transitions the inefficient mechanical differential into more efficient SW where improvements in regen, handling, performance and durability can be realized across all model lines simply by improving SW.
Linking FSD NN path prediction into a SW based differential further advances handling and regen.
This allows the same dual motor drive unit to be used in the front which brings Tesla into a true 4 motor configuration sooner further advancing improvements in regen, handling, performance and durability while simplifying production options.
Thermal management opportunities are improved. (Probably towing performance as well)
