The other reason hydrogen for land based transport is a dumb idea is that I have no doubt Megacharging will work and fast charging in general will get faster. I''m also very confident a Megacharger can be built cheaper than a hydrogen refuelling station.
I don't think the problem will be the charging rate. That's particularly relevant for long-distance trucking, and it should be fast enough to fit within Federal legal requirements for driver hours.
I think there's much more likely to be a problem with power requirements.
Diesel:
Max pump rate is 60gpm, but let's say typical rate is half that at 30gpm.
Typical efficiency is 6mpg, so that would pump 180 mpm, which is 10,800mph.
Let's be generous and assume 1kWh/mi for a Tesla semi.
A literal Megacharger would provide 1,000 mph.
So to match current long-haul refill capacity, a Tesla truck stop would need to replace each pump with up to 10.8 Megachargers. That would mean
10.8MW per current pump.
It could offset that requirement somewhat with:
- off-time destination charging at lower power to reduce long-haul charging miles required.
- reduced power demand if drivers are on break with additional time to spare for charging.
- (eventually) platooning to increase efficiency and lower overall power requirements.
- local battery storage to reduce peak grid demand.
The real Nikola problem is that even if HFCV is successful, it's on the wrong side of the moat.
