Not sure which sounds you are looking for, but I found the Scanner Sweep and Turbo Boost here.Now I just have to find a good clean sample of the noise KITT made without dialogue or an episode's score behind it.
just too bad my 2018 doesn't have the speaker, still have to resort to lowering the window and cranking up the tunes to get people to move out of the way in a parking lot
With an ICE vehicle, there is engine noise. An electric vehicle is' much quieter at low speeds, so the speaker gives a minor auditory warning as to its presence without necessitating use of the much louder horn.Horn broken, right? I can't remember ever, in 50 years of driving, having to noise nudge human beings out of my way
While I haven't heard it in the wild (my 3 was made shortly before they started adding it), I believe it will be something I would like to add to my car. There have been instances it would have been handy (there's been a couple of times I just had to wait for slow people as I didn't want to honk my horn).
But more importantly can it fart at people in parking lots that can't here you coming, this is a top priority.
It only took 15 months, but you got your wishBut more importantly can it fart at people in parking lots that can't here you coming, this is a top priority.
I’ve had the same sound, kind of a whirring noise, for months. I thought there was something wrong with the front motor. It’s not very loud on my car.. I can’t hear it with the windows up.I picked up my 2020 Model 3 from the service center this past weekend and immediately noticed a new sound coming from the front area of my car while driving out of the parking lot. It was a "hissing" sound that got noticeably louder as I accelerated, and it would turn off when I reached about 20 mph. When I spoke to my service advisor about it, I was dismayed to find out that they had updated the firmware in my car which added a wonderfully annoying sound when driving under 20 mph. I understand it's necessary for safety reasons but the sound is audible when my windows are closed. I wish I can turn it down a few notches.
5 minutes, just unplug the connector. You can just leave the speaker attached to the mounting plate.Pull the speaker out - it’ll take like 30 mins.
When driving forward, it plays a white noise/static sound. If you mute the audio in the car and drive slowly, you should be able to hear it.Question: In my 2021 M3P I only ever hear the pedestrian warning sound when going in reverse; however, I never hear anything going forward. Is that something I have to somehow enable? And, if so, how can I get the same reverse sound effect when driving forward?
Thanks.
Just unplug it. 2 seconds.as an alternative to removing the speaker, I installed Isolation Kit for PWS from Abstract Ocean.
easy enough & fully reversible.
Does anyone have any update on a potential retrofit of the Pedestrian Warning System on a mid-'19 Model 3? I think mine was built in April or early May '19, and it was right before it was offered as standard. I actually really would like to get this installed. Has anyone been able to successfully get it retrofitted? There was a rumor that the wire harness is tucked up in there behind the speaker grille opening (which I have) but I haven't torn apart my lower valence to find out. TIA.
