I don't doubt that; SR can be very efficient! I expect that trip would use: 186Wh/mi*30mi / 209Wh/rmi = 26.7 rated miles
That round trip should have used: 90.3mi*254Wh/mi / 209Wh/rmi = 110 rated miles
And your actual range at this same average consumption (assuming your 100% is 240 miles - can't tell from your post what it actually is) would be:
240 rmi * 209Wh/rmi / 254Wh/mi = 197.5 miles. (Plug in a different value than 240 for your 100% if needed.)
Note I'm not talking about the estimated range on the Energy Consumption graph here: That is given by: Rated Miles remaining * 219Wh/rmi / (Current averaging Efficiency) (Doesn't use the 209Wh/rmi number for whatever reason.)
I'm talking about the rated miles shown on your battery gauge for all of the "rated miles" info above. If it shows less (at 100%, or extrapolated to 100%) than your original 240 rated miles (220 rated miles if you have an SR), then that means you very likely have less energy available, above 0 rated miles, than you had originally, for whatever reason.
I understand what your point is (have an SR so 220 rated miles). My point is that unless someone has recently confirmed through a real world range test or a controlled environment test that what the car is reporting in range on the battery meter is actually correct, we are all just making assumptions. The meter could have changed through a deliberate measure by Tesla to change what 0 means or it could be a software bug.
