All used 75D uncorked?
Discussion in 'Model S: Ordering, Production, Delivery' started by Jomak, Feb 13, 2020.
  1. Jomak
    Jomak Member
    ATL
    When I look at all the used MS 75D all of them report 4.2 sec 0-60. Does that mean all of them are uncorked even the 2016 models which are the ones I am looking at? I know I saw a thread about misleading info and one even said 2016 75Ds can't get the upgrade.
    Can you please explain the upgrade process? What models qualify & years?
    If I want a used MS with AP2 or > (for the upgrade capability) and <5 sec 0-60 times under $50k what are my options? I was hoping all the 2016 75D models had the upgrade like Tesla reports.
    Thank you, I know enough to be dangerous :)
  2. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    Paging @Krash. @Krash to the white courtesy phone please.
    • Funny x 3
  3. Krash
    Krash Data Technician
    Intermountain US
    So a bit of a history lesson will illustrate what we don't know.
    On July 2017 Tesla announced that it was giving a performance increase to the 75D. It "uncorked" all of the cars yet to be delivered. Now Tesla had made a change to the drive unit and designated it with the code DU00 (or DU01 for the large rear motor) two weeks earlier. But interestingly some of the cars getting uncorked before delivery and in inventory did not have the new rear drive unit. So could Tesla uncork a bunch of the older cars? Why yes - and yes it eventually did. Tesla sent a list out to the service centers and created a way for them (but not you) to check if a car's VIN was eligible. The service center's got good at uncorking them. Most could do it in a few hours, although there were a few that only got half uncorked on the first try. A bigger problem was that some cars got sold advertised with the new faster specs that couldn't be uncorked. Likely some folks missed the idea of uncorking all together and never did it.
    How far back could it uncork them and what hardware was required? Did it require the Iconel contactors? Something else? Nobody is sure.
    But if you are looking at AP2 2016 cars they can all be uncorked, since AP2 was introduced in the last three months production of 2016. As a bonus you might get leather, alcantera and likely free transferable supercharging. Good choice.
    • Informative x 5
  4. cucubits
    cucubits Active Member
    TX
    Also, don't take the word of just one service center. On my first try, I was told clearly by both the receptionist and a "technician" that my car absolutely cannot be uncorked. Went to another service center and they happily uncorked it in about 2 hours.
    • Disagree x 1
  5. Jomak
    Jomak Member
    ATL
    If it's a 75D with AP1 could it be uncorked?
    and to the regular 75 cannot be uncorked?
  6. Krash
    Intermountain US
    All 75Ds had at least AP1. Some could not be uncorked.
    The RWD S75 later came uncorked only if it had that mid 2017 (DU01) drive unit.but earlier models could not be uncorked later.
  7. vcrispino
    vcrispino Member
    TX
    Do you mind sharing with SC did the uncorking and when? I'm also in TX but running into roadblocks when requesting uncorking.
    Thanks
  8. cucubits
    TX
    Sure. Plano Service center told me my car couldn't be uncorked and sent me away to pound sand. Then I made an appointment with Dallas Cedars Service Center where they immediately knew what I was talking about and uncorked it in a few hours.
    I posted pics of the service reports from both service centers on another thread around here, mind blowing and sad to see completely opposite results from basically the same company.
    • Disagree x 1
  9. vcrispino
    vcrispino Member
    TX
    Awesome thank you! I will give them a try, Plano told me to pound sand as well.
    I did find this setting:
    Perf_Config: Base
    Not sure what means since there isnt a P1 or P2.
    Thoughts?
  10. Cheburashka
    Cheburashka Active Member
    Los Gatos, CA
    The perf_config doesn't mean anything any more. They removed the visibility of whether it's uncorked from the API almost a year ago.
  11. vcrispino
    vcrispino Member
    TX
    Well in that case, I'm going to try the Dallas SC and request the uncorking, hopefully that does it. I do know I can get 5s 0-60 using a GPS app, so I assume the car is corked.
    Thanks
  12. cucubits
    TX
    Yes, it's very easy to tell the difference from 4 to 5 seconds 0-60 times, even if you just ballpark it with a phone timer. The difference is very noticeable.
    • Disagree x 1
  13. SilverGS
    SilverGS Active Member
    Ontario
    It certainly is!! :):) I had mine done a couple of months ago and it feels totally different.
  14. vcrispino
    vcrispino Member
    TX
    Hopefully they understand what I'm asking for, so far no luck with the Plano SC. Once my App is out of service I will request uncorking thru the App and select Dallas for the SC.
    I am really hopeful this works!
    Thanks
  15. vcrispino
    vcrispino Member
    TX
    Do you mind sharing how you got in touch with them, did you just schedule service thru the app choosing Cedar Springs as the SC or did you actually call them? I'm not able to get thru, they keep referring me to use the mobile app.
    Thank You, appreciate your input.
  16. cucubits
    TX
    Yes, through the mobile app. I don't remember exactly which section I selected, maybe software update and it showed me the list of nearby service centers.
    • Disagree x 1
  17. vcrispino
    vcrispino Member
    TX
    Ok cool, thats what I did as well.
    Thank You!
  18. cucubits
    TX
    I found the service reports I was mentioning. They're for the same car, same request by me:
    Plano Service Center:
    Dallas Cedars Service Center:
    I wish there was a way to show this to the manager from Plano, who knows, maybe they could take a look at their techs and their "expertise".
    • Disagree x 1
  19. vcrispino
    vcrispino Member
    TX
    AWESOME! I am going to print this out and show them!
    Cant thank you enough, hopefully this works. If not, I'm going to trade it in for a 2018 model, too bad I just got this one 3 weeks ago.
  20. vcrispino
    vcrispino Member
    TX
    I don't know if I'm dreaming right now, but I requested the uncorking via the app yesterday. Just about an hour ago I got a txt from a tech, letting me know they could send me a firmware update OTA and get it taken care of now!
    So yeah! I'm currently downloading the update and I hope to see 0-60 times drop!
    Can this be true?
