Alloygators?
Discussion in 'Belgium and the Netherlands' started by Lycanthrope, Sep 15, 2017.
  1. Lycanthrope
    Lycanthrope Active Member
    Brussels
    Hi Folks
    Anyone had these fitted? Any good? Where? Etc.
    Having just taken delivery of my MX with 22", I fear for my rims' lives :eek:
    Cheers, Dave
  2. busaman
    busaman Member
    suffolk UK
    yes i have them now on my second set and the saved my rims many times.... if your competent with fitting things do them yourself otherwise get a pro to do it.
    whe i did my first set it took 2 hours now only 1 hour..
  3. Ton S90D
    Ton S90D Member
    Netherlands
    Just look for a dealer in your neighborhood (not that hard to search it yourself) ;)
    Dealer locaties
  4. herb_k
    herb_k Member
    Van Moscow tot Noorwegen, meestal Almere
    I also fitted a "few" including a couple of Model X's.
    If you want more info, let me know.
  5. Lycanthrope
    Brussels
    Thanks, didn't see they had an NL website. Pretty poor presence in Belgium though :-/
  6. Lycanthrope
    Brussels
    @busaman, @herb_k - they look OK, don't spam the lines of the rims?
    I'd judge myself semi-competent with mechanical stuff. Changing wheels I can do no problem, fixing iPhones, no problem. Difficult to judge :D
  7. RandyS
    RandyS Fan of Elon
    San Diego
    I've had Alloy gators on my Model S with 21" wheels, and can tell you about my experience.
    I installed them myself, and it is time consuming. I deflated the tires a bit, one at a time, and used water with soap and a good mallet to whack them into place.
    When you first get the Gators installed, they look pretty good. And they definitely provide protection. They did save one of my wheels on one occasion when I was coming out of a parking garage with a circular driveway and the Model S was just a little too big for the small turning radius and I rubbed the curb. That's the good part...
    The not-so-good part is what happens when you need new tires, which for the 21" wheels is about every 25,000 miles. The tire shop I use had never seen them before. They agreed that they would just take off the gators when dismounting my old tires, and they put them in the trunk.
    My original plan was to put them back on myself after the new tires. But coincidentally, the tire shop had scuffed two of my wheels with a wire brush / drill motor when pulling off the balancing weights. Frustrating. But they paid for a local mobile service to come to the house and refinish those two wheels. It looked great after the refinish, a perfect match in color (silver).
    But before that refinish work was done, I also realized that the act of me putting on the gators originally had put marks on the edge of the wheels (after all, they use these serrated edge bits to grip the wheel and stay on when you pound the he!! out of them to get them in place between the tire and wheel. In addition, the original gators looked a little weathered, and I didn't want to put them back in place as-is. And there was the one wheel that rubbed the curb. That gator didn't look good at all.
    I thought about buying a shiny new set of gators to put back on, but ultimately decided that I didn't want to go through the hassle of doing that and going through the installation. And having the first set of gators while driving my Model S for the first 25K miles was probably a "Training ground" for how to avoid curbs, etc.
    So for the sake of keeping my wheels from getting additional installation marks on them, and avoiding the cost of buying another set of gators (not exactly cheap), I decided to go without. If I ever have an incident with a curb, now that I know about the mobile refinish service and their great work (Velvet Touch, if anyone in San Diego cares), I will just use them to keep the wheels looking nice...
    That's my two cents worth....At the end of the day, I'm not sure that the "cure" is any better than the "disease" when it comes to the gators...
  8. scaesare
    scaesare Well-Known Member
    NoVA
    My experience is more along the lines of that of @RandyS , I installed them myself. I did save myself from curbing my tires once.
    When I got a tire puncture I opted to replace a pair of tires, and the shop had to remove the gators. I realized that they catch a little grime and dirt underneath them, and gum up the edge of the rim underneath them. Most of that cleaned off, but I've heard of others say it actually wears the rim finish over time.
    I ran with just two for a while, and when I changed the other set of tires, did without. I've been careful and not curbed my rims in 100K miles. I also don't have a small tire air leak that plagued me for a while.
    They do work for their intended purpose, but they aren't without considerations elsewhere.
  9. Lycanthrope
    Brussels
    Valuable info, guys, thanks
  10. busaman
    busaman Member
    suffolk UK
    yes the look good (the last iphone i fixed i cracked the glass lol)
    here in the UK the roads are much smaller than in the US so the chances of curbing ar dramaticly increased when i changed tyres @25ki threw them away and fitted new (the tyres were £1300 so £80 for a new set of gators is no sweat)
  11. BjörnTM
    BjörnTM Member
    The Netherlands
    I had them installed, but when they were removed later, my wheels were damaged due to tiny sand/stones between the alloygators and the rims. Not using them again. If I now damage a rim, I know I can have them fixed at around € 100 per wheel.
    @RandyS which mobile service was that? Until now I only found services where you need to bring in your car/wheels, which is quite inconvenient ;)
  12. pvh
    pvh Active Member
    Netherlands, Rotterdam Ballade (Aria)
    Alloygators=ugly
    Learn to parc or fix when damaged...
  13. busaman
    busaman Member
    suffolk UK
    the early ones with the pointed edge were ugly the new rounded ones are much better an a pretty close coulor match on my 21" turbines. its easy to say learn to park but i live in the countryside with small windy lanes and narrow streets with kerbs parking is not the issue but eavsive action from cars coming at high speed towards you with nowhere to go.
  14. pvh
    pvh Active Member
    The :) was lost... but didnt knew there are better looking ones now also avalable.
  15. RandyS
    RandyS Fan of Elon
    San Diego
    The mobile service is here in San Diego, CA...A long way away from you, unfortunately. The service is called "Velvet Touch" and they come to your home or business to refinish the wheels...They have figured out the exact match for the Tesla paint colors and their work looks really great when they are done. They prep the wheel very well, and then use an airbrush to do the painting....
  16. Lycanthrope
    Brussels
    Thanks for the extra info chaps!
  17. busaman
    busaman Member
    suffolk UK
    this is the new profile
  18. busaman
    busaman Member
    suffolk UK
    and another angle
