The 18" rims are 8.5" wide so the optimum tyre width is 235 or 245. If you put on 225 then the walls of the tyre looks stretched and 255 would look squashed in - anything outside of 225 to 255 would be unsafe.
If you change the width then you need to consider the profile of the tyre so you keep the circumference of the tyre consistent, otherwise your speedo will go too far out of calibration.
There are plenty of tyre size calculators on the web which will help.
