Alternative to Camco Heavy-Duty Extension Cord in Europe?
I recently found myself in need of using an extension cord to charge my Model 3. I suspected that an ordinary cord couldn't do the job, and after a bit of browsing I found that several Tesla owners based in the US recommend using this bad boy:
Camco 50' PowerGrip Heavy-Duty Outdoor 30-Amp Extension Cord
But I live in Europe. Can someone recommend an alternative extension cord that works with the plugs used here? I found this product on Amazon DE:
Emos Extension Cable with 2 Schuko Sockets, Double Extension
But I am not sure if it would work and it would be as safe as Camco. I am no electrician so I thought to play it safe and ask you guys.
The cable you found on amazon is only 1,5mm2, so useless for charging an EV.
You need a cable with 2,5mm2 wires and use the 16A CEE plug if possible.
Reactions: paulrberg
