Always asking to connect to WiFi
Discussion in 'Model S: User Interface' started by ACDriveMotor, Mar 9, 2014.
  1. ACDriveMotor
    ACDriveMotor Member
    Seattle, WA
    My car has always been connected to my home WiFi since delivery with 5.6. Starting this week every time I get in the car it has the nag dialog up about connecting to WiFi. I will try rebooting the console since I just updated to 5.8.10. But wondering if others are experiencing this as well.
  2. wycolo
    wycolo Active Member
    WA & WY
    NAGs:
    1. The WiFi whenever I stop somewhere in civilization. I have no WiFi at home.
    2. Clock always 1 hour late, since forever.
    3. TPMS warning always with the snow set due to no sensors.
    4. 'Key battery needs replacement'. I did so but alas. At least it is not the 'needs replaced' syntax you see so often.
    Rebooting both screens did not help. I should try the yellow fuse - remove for 60 seconds cure!
  3. Lump
    Lump Active Member
    So. Cal.
    Remove your network, then re add it.
  4. iffatall
    iffatall Member
    SF Bay Area, CA
    There is a short discussion about this here:
    Set Up WiFi Popup
  5. ACDriveMotor
    ACDriveMotor Member
    Seattle, WA
    A center console reboot (5.8.10) did not fix this for me. Removing and re-adding my home WiFi appears to have fixed the issue.
  6. Kipernicus
    Kipernicus Model S Res#P1440
    Belmont, CA
    I'd like it to stop asking me about WiFi after the 10th time I pressed "Not Now" in any given location.
  7. ACDriveMotor
    ACDriveMotor Member
    Seattle, WA
    It no longer asks me in any location, which was the behavior I had starting with 5.6. Have you tried removing and re-adding your home WiFi?
