Me too ...I want them!
It will be interesting to see if they are 'Plug and play', or if we will have to do some wiring modifications to accomplish the change.
I was told that it was a combination of DOT rules having to do with the amount of "red" brake lights meeting a minimum, and that the "red" on the hatch doesn't count
I don't think you can mount the EU taillight in a US car since the chargeport is different en that's integrated in the taillight.
Check out the Ebay link I posted. It doesn't look like the charge port is attached.
It is NOT in fact, BS. It's because of US DOT regulations. The US DOT requires a minimum SURFACE AREA for brake lights and turn signals. 7.75in^2 each. So if you look at the euro lights on like a Corvette, the brake light lens is smaller because the amber turn signal takes up part of the area. That is what is not legal in the US. They need the whole area to be the brake light and the whole area again to be the turn signal in order to satisfy the surface area requirement. In the rest of the world they just have a luminosity requirement, only the US (AFAIK) has this surface area requirement in addition to luminosity. So if you want a compact light cluster, the same lens needs to do double duty. So it becomes a function vs form thing - if you want small light clusters you have to go w/ red brake lights.Seeing as how studies have shown a reduction in accidents with the use of amber rear blinkers, why wouldn't the "world's safest car" offer these to the USDM? I would love to modify my tail lights, but what would be the rear blinker (smaller "U" shape in the outer light) is red and also used with the brake light. Maybe I need to wait and see if they pop up on Ebay over there, someday
As I understand it the EU only has a luminosity requirement so as long as the lights are bright enough they can be whatever shape/size. In the US, separate amber turn signals are legal but you must satisfy the surface area requirement for the brake lights. I haven't measured it but I assume if you remove the inner "c" of lights from the brake light then the Model S will not meet the brake light surface area requirement. If it did I assume Tesla would have built the car this way as it would be simpler/cheaper to have a single taillight used worldwide.Can't speak to US DOT, but I always thought US and Canadian regulations were pretty close in this regard (not 100%, but close). I was given to understand that EU-spec tail lights, while not required, are legal here. Anyone know for sure?
True. Makes you wonder why Tesla didn't consider this in their tail light design from the get-go.
One significant problem with rear amber turn signal lights is that when people turn on their emergency flasher you can't tell the difference between the front and rear of the car. This is particularly a problem on two lane roads in heavy rain when some drivers use their flashers to indicate they are going slowly. The other problem the bright amber flashes 'hide' brakes lights.
