Amusing Roadster problem
Discussion in 'Roadster' started by adiggs, Jun 18, 2013.
Tags:
  1. adiggs
    adiggs Active Member
    Portland, OR
    So I have this amusing problem with the Roadster - I'm hoping somebody else has had something similar and can make a suggestion.
    The knob for the fan control got left behind during a sharp acceleration (literally - I put my foot down, and the knob stayed in place while the car took off). End result is that the knob is somewhere under the driver's seat.
    Any suggestions for how to get something small out from under the driver's seat? I've got pretty long fingers, but not that long. I'd sort of like to put that knob back where it belongs :tongue:
  2. ChadS
    ChadS Petroleum is for sissies
    I don't even know what you call them, but I'd use one of those flexy-grabby things that are often used to pick up screws dropped in to engine compartments, like HERE.
    One of the most useful tools I have ever owned...
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    The Roadster HVAC knobs are cheap and break frequently. If it's still under warranty get them to replace it.
    If it's not under warranty, do what Chad suggests and then use some glue on it...
  4. Pantera Dude
    Pantera Dude Member
    Long Beach, California
    How about a coat hanger with a hook on the end.
  5. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    The seats are not that hard to remove. 4 bolts and about 30 minutes and you can lift them up for cleaning or get things under the seat. Note add another 15 minutes to remove the full seat as you have to also contend with seat belt attachment.
  6. Vexar
    Vexar Member
    Plymouth, MN USA
    Put some earphones on and use an electric leaf blower from the back seat. It's the only way you can respond to how the knob got there in the first place. Be careful with the upholstery. You might also use a shop vac, but that's not nearly as impressive.
  7. pharma5
    pharma5 Roadster F#25, Model 3 #36xx
    central NJ
    Reverse the process - sharp deceleration (safely of course).:biggrin:
    Alternative: back-scratcher with double-sided tape on the end. Less fun...
  8. adiggs
    Portland, OR
    H'mm - I have a leaf blower too. I've even used it a few times for drying the car after washing.
    "what are you doing"
    "dusting under the seats"
  9. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    Wasn't there a story about that used to recover Elon's wife's phone (or something like that)? Rather than take the seat out, just brake sharply.
  10. Doug_G
    Ottawa, Canada
    That does work. Last year I lost something, but I didn't realize that I had lost it in the car. I found it under heavy braking when it suddenly popped out from under the seat!
  11. Owner
    Owner Active Member
    San Francisco Bay Area
    I put my registration under the seat, since I had a 1.5 and no glove compartment.
    A cop did pull me over for a ticket, and I couldn't get the registration out. He didn't fret over it, and gave me a ticket anyways.:eek:
    That old registration might still be under that seat.
