Andersen A2 Faceplate Corrosion
Just to advise, if you have an Andersen outlet that has been installed for a few months, you may want to double check you don't have any faceplate corrosion. Ours has been installed for about six months, and the paint has started to bubble on the front. It seems that the screws that hold the nameplate on removed a tiny bit of paint, which started the process. Andersen very quickly provided a new front plate, albeit with the same screw damaged paint that we will paint over.
Reactions: Zakalwe
