Anheuser-Busch Ordered 40 Tesla Semi Trucks
Discussion in 'Semi' started by TMC Staff, Dec 7, 2017.
Tags:
  1. TMC Staff
    Budweiser beer owner Anheuser-Busch has ordered 40 Tesla Semi trucks, according to The Wall Street Journal. James Sembrot, the company’s senior director of logistics strategy, told WSJ the company has aggressive goals for efficiency and believes Tesla could be an important part of the plan. According to the article: Anheuser-Busch spends about $120 million on fuel...
    READ FULL ARTICLE
  2. bcsteeve
    bcsteeve Member
    Kelowna, BC Canada
    Or 300-mile range, which would likely be what they're buying if they are using it for 150 to 200 mile runs. Why assume they're getting the higher-range version?
  3. STart
    STart New Member
    Texas
    • Disagree x 1
  4. STart
    STart New Member
    Texas
    Because they have to get there and back. There will not be fast chargers at the destination.
  5. bcsteeve
    bcsteeve Member
    Kelowna, BC Canada
    You're right. I misread it originally. I thought they meant round trip, but that's not what it says.
  6. Peteybabes
    Peteybabes redneck drivin' a tesla...
    'murica
    I wouldn't be surprised if they put fast chargers at the delivery points so they can grab a charge while they're being unloaded and save a ton of money on the trucks
  7. bcsteeve
    bcsteeve Member
    Kelowna, BC Canada
    Why not, right? Unlikely the chargers cost $30k and assuming multiple trucks to the same destinations, that could represent significant savings. On the other hand... spending the extra on the trucks gives considerable flexibility for route expansion.
  8. deonb
    deonb Active Member
    Redmond, WA
    Actually I think a DCFC capable of the ~500kW that’s needed to recharge while unloading will be quite a bit more than that.
  9. Peteybabes
    'murica
    It wouldn't necessarily need to be that powerful...
    Remember a truck takes 30-60 minutes to unload so even at 50% the driver could easily make it back to the bottling plant.
    How? The truck will be empty. Everybody seems to forget that these trucks could probably go 800-100 miles empty so a full charge wouldn't be required to go home just a quick boost...
  10. dhanson865
    dhanson865 Active Member
    Knoxville, Tennessee
    Even if they did have a charger at both ends consider degradation over time, weather, construction detours, the unknowns. I sure wouldn't buy the bottom range version for a 200 mile round trip run if I wanted the vehicle to handle my needs for many years to come.
  11. NeverFollow
    NeverFollow Active Member
    #11 NeverFollow, Dec 7, 2017
    I noticed some time ago that they already have a Solar Plan and Windmill at their Fairfield brewery and tasting room:
  12. avoigt
    avoigt Active Member
    Germany
  13. Peteybabes
    'murica
  14. avoigt
    Germany
    The good news here is that this is not a test order of a few trucks to test them out. If you go in with 40 to 50 in than the decision makers are very much confident of the positive $ impact.
  15. bcsteeve
    bcsteeve Member
    Kelowna, BC Canada
    Sysco has over 500 trucks in Canada. 50 is a significant test, but still a test :)
    I certainly agree... that's a strong statement of confidence.
  16. zecar
    zecar Member
    New York/Chicago
    Why would a customer have a Tesla charger? Truck will likely do a round trip and charge overnight at AB.
  17. Atypicalguy
    Atypicalguy New Member
    Los Angeles
    The maintenance costs are drastically lower on an electric. Minimal powertrain, much less brake wear. For high mileage, short haul commercial applications these things will take over. The bean counters will win.
    I am with whoever said that chargers will not be cheap. The power draw will likely require a large battery, unless like anheuser there is already high voltage 3 phase power on site. Interested to see how it all plays out. I am guessing we will see lots of them hauling out of the port of LA to rail heads, if they ever make it to production that is. There is some pretty stiff competition in this segment and major outfits that actually know how to build vehicles at scale volume are not going to be sitting idly by.
  18. Mbrockus
    Mbrockus Member
    Arlington, WA
    Let’s not forget that the range calculation is based on an 80k load at highway speeds.
  19. etmax
    etmax Member
    Australia
    The question has to be how many of their truck fleet is replaced each year due to wear out etc. If it's on average 50 then this is definitely not a test.
  20. e-FTW
    e-FTW New electron smell
    San Francisco, CA
