Not sure exactly. Can you use the feedback report and select to attach the trip?
done
@sdorn brought me an interesting trip that had a bunch of days with small out and back trips in an area with no superchargers. He treated each day as a separate segment which is exactly what he should do. He just needed to manually adjust each day's start time to ensure the weather was correct and carry over the energy remaining from the prior day to the start of the next day. I ran it through the next major version of the app and it will automatically reallocate the energy as well as start the next segment on a default time of day, next day, in the settings. So all of this will be much simpler then.
It's in the FAQ in the app, but it's one of the less obvious features.... I've found the best way is to create a trip, enter the address(es), then go to that endpoint/waypoint, click on the pin, and you will see the (empty) heart symbol as one of the options in the info box. Clicking on it will 'fill' it and create it as a favorite. The 'manage favorites' items will let you delete them.Last night I downloaded the app and tried to use it. I could not figure out how to add my home address into favorites. Also, each time I tried to set up this Friday's trip it would route me the most direct, when I need to go another way. I finally figured out to set up the Supercharger I wanted to use on a "Add Waypoint". Still, I had to keep starting over by clearing out old with starting new, entering my home address again, as well as destination address. After about 6 or 7 times I finally gave up. It would be nice to have a "How to use" help.
Actually you can't do exactly that in EVTP, either. The route planners all use average speed data, not speed limits. I wish they would/could use speed limit data, but I don't think it is readily available.Great app.
Just waiting on the option to adjust the speed to 5 mph over the speed limit (my cruising speed on interstates) like you can do on evtripplanner.com.
Once you add that feature, I will purchase.
It's on the ToDo list for a complete manage Favorites feature. Someday ...I'd like to be able to enter them in the 'manage' area, also.
If you have the Pro version yes. It's in the New Trip dialog.Looking forward to the new update! Sorry if someone else has already asked this, but is there a setting for round-trip? I'm trying to see how a trip from home to the airport to back home would look in the planner but I don't see a way to do this. Thanks!
Not exactly sure if I have your question correct but here goes:Looks very flexible. Will the software still limit the values based on the car's published maximums, or will it go with our numbers? I like to play "what if..."
Ok, so if I tell it my 90% range is, say, 350 miles, it won't use that in the calculations, right? (The use case is to do what-if experiments for a possible future car purchase.)The app is not constrained by any EPA or other range metric. It uses the available battery capacity as stated by Tesla and refined by your setting in My Cars for its current capacity. Then the app uses a slew of things to figure out how much energy you need to get from waypoint to waypoint such as wind, road conditions, temperature, precip, elevation, cabin temp, drive distance and speed.
No. It will use that in the calculation. It will limit the capacity of available power. Hence how far you can go and how much the battery will charge to in kWh.Ok, so if I tell it my 90% range is, say, 350 miles, it won't use that in the calculations, right? (The use case is to do what-if experiments for a possible future car purchase.)
How's that update going? Big trip starting later this week.Another tease of the next major release
It's coming along, but not ready for this weekend.How's that update going? Big trip starting later this week.
