So i have only had the car for 3 weeks, in the beginning the app was connecting ok, sometimes it took 10 seconds but most of the time it was a second or 2 and it had connected to the car.
But now "all of a sudden" it is really hard to get it to connect, especially at home, when it is charging, sometimes i want to manage how fast it charges due to solar panels and house consumption not having to go over a certain max figure.
I will open up the app, the app will say that it is connecting and that it has not seen the car for X minutes, but the wheel just keeps spinning and spinning, and sometimes it connects after a minute, sometimes it will not connect.
Sometimes it will even seem as it has connected, but if i adjust the charge amps, it will just jump back to whatever it was previously set to, and the app says "Failed to set charge speed".
I tried "everything".
The car sits in the driveway, not the best of wifi so tried turning off wifi to the car, thinking that it might be because of a very low signal wifi, but this has not helped.
Tried turning wifi on and off on the phone, thinking it could be something with my home wifi, and let the phone connect to 5G instead. There is plenty of coverage at home for cell networks.
I also tried the brake pedal and both scroll wheels pressed until the car reboots and i have tried restarting my phone and even tried resetting the app on my phone and starting over, thinking it might be the app, that had a problem.
Funny thing is....If i have the app open and have had the wheel spinning for minutes, without ever connecting, if i then go to the car and open up the door, it will almost instantly connect to the app, and i can then control everything via the app.
To me it seems that the car might get into a sleepmode that is a bit "sleepy" since it will not respond, and when i open the door, the car exits the sleep and suddenly sees that the app is trying to communicate.
Sentry mode is set to off at home, as i have camera's pointing at the car in the driveway, so i dont want to "waste" the energy, that sentry mode uses.
Has anyone experienced anything like this.
PS. The phone key works flawlessly 99,9% of the time so even though it does not want to speak to the app, it does recognise that the phone is near the car.
