Another day, another bug - Overheat protection
Discussion in 'Model S' started by jddssc121, Aug 27, 2017.
Tags:
  1. jddssc121
    jddssc121 Member
    Las Vegas, NV
    I have overheat protection enabled... just checked my car. It's 113 degrees in the cabin.
  2. MichaelS
    MichaelS Supporting Member
    Hayward CA
    I was in Redding CA a few weeks ago. The interior temperasure was 114. Good time to try that new feature. After I turned it on the temperature oscillated between 95 and 109. Still too high in my opinion.
  3. dmcmillen
    dmcmillen Member
    Durham, NC
    Is your battery state of charge ≤ 20%?
  4. VikH
    VikH Member
    MN
    Yes, it does not activate with low SOC. Also, I believe the feature turns off after the car sits for more than 12 hours.
  5. jddssc121
    jddssc121 Member
    Las Vegas, NV
    Battery had 200 miles left. Had only been out of car for 2 hours.
  6. Brian-MS90D
    Brian-MS90D Member
    Cincinnati, OH
    Weird. It works well for me.
  7. jddssc121
    jddssc121 Member
    Las Vegas, NV
    It normally does for me too.... but today it didn't
  8. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    What did you use to measure interior temp? Were you measuring air out of direct sunlight?
  9. jddssc121
    jddssc121 Member
    Las Vegas, NV
    The app tells you the temp
  10. florida2017
    florida2017 Member
    Osprey Florida
    I have seen this also, I think the AC system needs to be on and ac turned on when you shut the car down. My thought is the system will turn on at 105 but if the ac was off it will not turn it on.
    I do not use auto for the ac. If you are in auto mode, it may be fine.
  11. D.E.
    D.E. Uncorked
    Ann Arbor, MI
    It is too high for comfort but it is survivable. It means one won't bake a child if the child is unintentionally left in the car. I see that as the primary advantage. Don't get me wrong, leaving a child unattended in a closed car is abuse and should include prison time. But in a Tesla with cabin overheat prevention, it is very much less likely to become a tradgedy. There is a huge difference in survival time at 95-109F compared to140-160F.
  12. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    Sad thing is it happens by accident.
    I have a totally unsourced memory that it's about one child a week in the US. Usually baby on the way to day care, and parent just drives to work and forget they didn't drop off.
    Bloody tragic, I don't know how I'd live with myself if it happened to me.
  13. David99
    David99 Active Member
    Brea, Orange County
    Dashboard for Tesla app is the solution. I use it all the time to keep the car at a reasonable temperature
  14. SMAlset
    SMAlset Active Member
    SF Bay Area
    Ours works pretty consistently and I've been monitoring it for several months now (and take phone screen captures periodically too). If the car's been parked overnight and sitting in the driveway I do sit in it each morning to activate the "timer" function. I have on a few occasions seen it go above 104-105F when I've checked the app for the first time that day, but I find that in those cases when I've checked the app and watch it, it will then bring it down to the appropriate range in a few minutes. Battery level never anywhere near 20% btw. For the life of us don't know why it happens occasionally and so now just make sure when it's hot and in the sun I just check the app early on in the day and going into peak heating time.
  15. MichaelS
    Hayward CA
    If the car is plugged in, the AC should run off the HPWC correct? When I tried it, the battery level dropped a couple of percent which indicated to me that it was not running off shore power.
  16. StefanSarzio
    StefanSarzio Member
    Herford, Germany
    Same here. It only does so while charging. So for pre-heating the car I also set the charge limit up when I start pre-conditioning.
  17. thecloud
    thecloud As rhythm raced inside, the ship came alive
    Sunnyvale, CA
    In my experience, you do not need Auto mode selected, nor do you need the A/C to be actually turned on when leaving the car. I try to always leave the car with the fresh air setting selected (which is a Custom mode), so any condensation in the ducts will have a chance to dry out, and I manually turn the A/C off.
    Overheat protection seems to always work fine for me when I check it via the app. I see the interior temperature hit 104F, then go down into the 80s, then climb again to 104 once the A/C goes off, and so on.
  18. jddssc121
    jddssc121 Member
    Las Vegas, NV
    Update - Tesla is saying this is a touchscreen bug. The screen thinks it's being touched when it's not.... (no clue why that would affect overheat protection). They have ordered me a new screen. Should be here in a week.
