We all know about the doorhandle issues. However, in all the topics about doorhandles I was not able to find what to check/repair with these specific symptoms. A broken micro-switch or detached cable seems rather unlikely in this case.
In short: Nothing works (mostly) on any of the doors on the left (driver) side. This includes: window- and mirror- controlbuttons, doorhandles,... Only the inside doorhandles always work.
Other topics with same problem: Please help , Door handles don't present on touch only (partially)
What happened
- Got in the car. Everything worked then.
- Got out of the car (forgot something) and got back 1 minute later, to realize the door wouldn't open.
- Both the front left and rear left handles were presented but didn't open the doors.
- Got in from the other side. Controls in the drivers door were still working.
- 20 minutes later: Controls didn't work anymore. All doorhandles were still presented when expected.
- 30 minutes later: Left doorhandles are not presented anymore (stays in the door).
- Every 5 seconds a sound is heard from the drivers door (sounds like the electric doorhandle-motor) when inside the car.
- 1 day later:
-- sound is gone
-- left doorhandles sometimes present again (mostly not) but still doesn't open the door
-- buttons on the driver's door sometimes work again but very very shortly (I assume the same with the rear left door)
-- only when using remote: 50% chance the rear left doorhandle comes out but retracts again after a couple of seconds
The doors on the right side (both doorhandles and buttons) always work.
Conditions: It was lightly raining and left the door open for 1 minute (coincidence?). I also washed the car 2 days before.
Already tried: reboot. Didn't help.
I guess it might be moist / water that causes the controller module in the drivers door to stop working. Or its contacts.
If yes: where is it located? What is the correct name or part-number of this part?
If no: what would be the likely cause? I very doubt it's a micro-switch or cable as then only a doorhandle wouldn't work.
What happened
- 1 day later:
-- sound is gone
