Another Model X Problem!!! 3rd row seat stuck in down position.
Debaser
107
135
Gallatin, TN
I have another problem with XerXes, my Model X. It was delivered about 2 months ago, but has only been in my possession for a couple weeks total. The first major problem was the driver's door being royally screwed up. Now it's the third row seat.
I laid the third row seat down using the shoulder button. Now the seat will not rise up, no matter what combination of button presses that I try. Any suggestions?
commasign
TeslaAdviceBlog.com
Aug 31, 2013
3,202
4,176
Davis, CA
After you press the button, wait a half second and then lift the seat up. If you wait too long it locks itself. If you try lifting too soon, it won't have enough time to unlock.
Reactions: Xcelerator
Debaser
107
135
Gallatin, TN
Thanks, but the button is eliciting no response. That is, when I press the button, the normal electronic noise is not there. It is dead.
xkwizit
816
869
Folsom, CA, United States
Have you contacted your SC about the issue? It's usually a good place to start. It's likely that the controller or the motor is dead. Is it with both seats or just one?
And what was the "royal screw up" with your driver door?
xkwizit
816
869
I did. If you notice in my OP, you'll see I have a lot of experience with the service center. They're not open today. Which is why I'm posting on a forum, and not there right now.
My bad..I didn't see your profile and check out your previous posts on driver door latch issues. Yes, that's been an Achilles heel for TM.
Debaser
107
135
Gallatin, TN
I didn't mean to come across as rude. I'm just trying to solve this problem, and the forums are usually a good source for this. I'm hoping someone has a magic bullet like, "open the fuse box, pull the fuse, put it back, and wham, it's done."
Reactions: xkwizit
xkwizit
816
869
No kidding. I just want to push my seat back into the proper position. I can do that with one hand in my 2013 Volt. Argh.
Well..that may work for you and other fit people just like non power steering used to. But power assisted seats are a big help for older people, people with arthritis and other issues not necessarily disabled people.
xkwizit
816
869
So let's start with ..is this issue with both seats or just one as they do operate independently?
Debaser
107
135
Gallatin, TN
Found the solution, which highlights a major design flaw. There was a small pillow in the seat that my daughter uses with her booster seat. The pillow is dark so I did not see it when I laid the seatback down. The seatback locked into place, making it impossible to lift up, but there was enough pressure from the pillow to prevent the shoulder button from working. I had to pull the pillow from the rear through the intersection of the seatback and the seatbottom. Then the button would work.
So resistance from below being present against the declined seatback prevents the button from working. If you have a small animal present, or God forbid you me child has a limb in the seat put there when you were distracted, the seatback will lock in the lower position, but cannot be unlocked without the animal or limb being forcefully pulled out. Very, very bad design. Just plain awful. And that's coming from someone who loves Tesla and holds Tesla stock.
xkwizit
816
869
Good find..and a great post! :)
Reactions: GoTslaGo
Electric700
1,707
370
Florida, United States
You should contact [email protected] about this. The latches should allow some flexibility, not lock if there's an obstruction, or not lock at all. I'm not even sure what the benefit of locking latches is when the seat is all the way down.
Reactions: GoTslaGo
Drivin
955
371
This is good info.
Tesla needs to add some sort of sensor (like on the Apple iPhone) that can determine if there is human or small animal part there and prevent the seat back from locking in the lower position.
That sensor can also provide info to prevent tragic incidents of people leaving their kids or pets in the car.
xkwizit
816
869
This is good info.
I can understand if the pet or child is sleeping and is left alone in the car and that's a whole different topic but I don't understand the need for sensors to prevent locking the seats as the child or pet will squeal from the pressure of the seat. That should be enough to warn you. Though it will make sense to have a weight sensor that will prevent folding the seat but I doubt you can get reasonable accuracy for the weight of a small pet.
Electroman
6,260
6,414
TX
Doors, locks, seats (for folding), frunk and even glove compartment are controlled through an electrical / electronic components. When a simple traditional solution would have been good enough.
I am just coming back from test driving an X. VIN 419.
xkwizit
816
869
I disagree. The electronic locks like for glove are so much more useful and safer when giving your car to valet. It would be literally impossible to lock your frunk for a valet. I have already mentioned in another post about power operations of the seats.
