Another one bites the dust (Suspected PEM and PEM Fan Failure)
Discussion in 'Roadster' started by shrink, Sep 18, 2017.
Tags:
  1. shrink
    shrink Supporting Member
    Phoenix, AZ
    Just got back from 2 weeks of traveling. I kept the Roadster in my friend's garage plugged into a 30 amp charging station while away.
    I noticed over the past couple days that the charging would frequently start and stop.
    I picked up the car this evening after work and got the error messages below.
    PEM is not cooling at all. I'm bummed. Had to pay for the tow, which was not cheap. I don't imagine this repair will be either. I'm guessing a new PEM is in order and new PEM cooling fans. I went out of warranty last year and they would not let me renew.
    Will wait for the news tomorrow. I might actually contact Gruber to see what they can offer since they're local to me.
    IMG_2505.JPG IMG_2506.JPG IMG_2507.JPG IMG_2508.JPG IMG_2509.JPG IMG_2510.jpg IMG_2517.JPG
    • Informative x 2
  2. bolosky
    bolosky Member
    I had similar things happen, and it was the fan but not the PEM. So, many hundreds of dollars, but not $10K when/if they can even get a new PEM.
    Keep your fingers crossed that that's all it is.
  3. MileHighMotoring
    Parker, CO
    Yes, also have Tesla check if it's just the connector like some of us have experienced. Again, the repair was hundreds and not $10k for that.
  4. shrink
    Phoenix, AZ
    Thanks for the feedback @bolosky and @MileHighMotoring. I really hope that's the case.
    Oddly, the Service Center never called me today and by the time I finished working, they were closed. I did, however, monitor car status via OVMS a few times. PEM temp has lowered from 143F last night to a most recent reading of 98F. I did notice the PEM at 120F earlier while the motor and battery were much lower.
    Hopefully that PEM is not fried. I anticipate a status update sometime tomorrow.
  5. shrink
    Phoenix, AZ
    Well, I received a text message just now:
    "Your Tesla repairs are still in progress, all parts have arrived and we are hoping to have everything completed by tomorrow afternoon.
    After looking into everything we found that there was a faulty input circuit board, witch we went ahead and replaced for you."
    That doesn't sound horrible! No word on cost or anything, but this sounds like really good news. I couldn't help but think the worst at first.
    I hope to breathe a big sigh of relief when I get it back upon completion of the repair. Hopefully, I can post a final update tomorrow.
    • Like x 4
  6. gregd
    gregd Active Member
    CM98
    If this board is internal to the PEM, that is a fantastic indication that Tesla's replacement strategy has changed.
  7. Roadster
    Roadster Member
    SoCal
    We need to seriously consider a group buy on PEM connectors, circuit boards, and SPAL dual fans and just have all our local SCs swap and install them prophylactically during annual service.
  8. hsull8915
    hsull8915 Member
    Fort Worth, TX
    #8 hsull8915, Sep 20, 2017
    If they are doing work without getting approval on cost, they must be doing it as Goodwill. That would be very cool of them, maybe since you kept it under warranty as long as you could? Hoping that is the case!
    Definitely curious if that is an internal repair to the PEM. As @gregd noted, that would be a complete 180 to what I experienced during my recent PEM issue that led to replacement. Again, hoping for the best for you, let us know what happens.
  9. Rotarypower
    Rotarypower Member
    Cary, NC
    @shrink any update? We are dying to find out which board was replaced, and was it handled under goodwill or did they charge you an arm and a leg? ;)
  10. shrink
    Phoenix, AZ
    Sorry about that. My week has been busy!
    Scottsdale SC took really great care of my Roadster. Here is what my Service Invoice reads:
    Corrections: Replace Charge Input Circuit (CIC) Board To Fix Inoperative PEM Fan
    After diagnosis, found a faulty charge input circuit board. causing corrosion at the power electronic module fan connector. Removed PEM from rear trunk and replaced charge input circuit board. Also replaced PEM fan connector and reassembled. Performed function test after all repairs have been completed. Found issue to be resolved.
    Parts Replaced or Added
    Part Quantity
    PCBA,CIC I/O WITH EMI CORES (6005208) 1
    Pay Type: Goodwill
    • Informative x 2
  11. shrink
    Phoenix, AZ
    Here's a screenshot for further reference. This honestly scared the crap out of me, but I'm relieved now. The community here is so knowledgeable and I'm so thankful the SC opened up that PEM and performed the repair.
    Hope my experience continues to add to the database and can be helpful to another owner in the future!
    • Informative x 2
  12. DeedWest
    DeedWest 2010 Roadster 2.0 - VIN 523
    North Dallas, TX
    Wow. That's excellent news. I'm thrilled to see that the SC took car of your car. Isn't 501 out of warranty as well? That's otherworldly service by SC standards!
    Perhaps it'd be cheaper to ship our Roadsters to Arizona next time the PEM has issues. ;)
  13. MileHighMotoring
    Parker, CO
    They did it for free?? Wow!
  14. hsull8915
    hsull8915 Member
    Fort Worth, TX
    Super awesome result! Thank you for posting!
  15. Rotarypower
    Rotarypower Member
    Cary, NC
    Did you perform a Jedi mind trick on the service rep. to get goodwill? What are the circumstances that caused them to diagnose, remove, and disassemble the PEM and replace an internal circuit board, then reassemble everything, test your car, and then not charge you a dime? Am I missing something?
    Awesome! Congrats on the getting your car back up and running.
  16. Rotarypower
    Rotarypower Member
    Cary, NC
    Another general question to our community......does Tesla publish TSBs for their cars? Is it possible that there is a TSB on this issue? If so, are they available on some of the 3rd party service related websites?
  17. bolosky
    bolosky Member
    They have them, or at least they used to years ago, but I don't know of any way to get them other than to have a friendly service person tell you about them. For instance, there was one many years ago about fixing the AM radio antenna in the Roadster so it went from totally useless to useless unless you're really close to the transmitter. They only did it if you complained about radio reception, though.
  18. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    By chance do you know the fix for that? That may be worth me ripping into the dash. I heard the one about the key FOB antenna and that change made a noticeable difference for me.
  19. gregd
    gregd Active Member
    CM98
    It was documented somewhere on this forum a few years ago. If I recall, the net of it was a strip antenna affixed to the passenger edge of the windshield, up against the trim. It did involve ripping the dash apart, however, in order to get access to the wires, though I would think you might be able to fish things through if you tried hard enough. But, don't expect amazing results. The car is one big RF noise generator, and AM radio is particularly susceptible.
  20. bolosky
    bolosky Member
    Yes, they run the antenna up the corner of the windshield inside the trim. I know, because the trim came off of mine (probably because they pulled it off to do this install and so weakened the adhesive) and I had to replace it, including threading the antenna up in it.
    The easiest thing to do might to be to ask Tesla to do it next time it's in for service. The TSB is probably still around (though you'll probably have to tell them about it), and so they'll do it for free, I'd imagine.
