I had a neighbor do my install a couple weeks back (thanks Shane!), he did an awesome job. I'm generally very happy with the sound quality. We ended up leaving it in phase with the stock sub after minimal testing; it sounded fine to me and in his experience running out of phase would generally cause a reduction of output due to cancellation. From the post above, it sounds like maybe I should try again running out of phase. Was the increase measured with an SPL meter, or just by ear and the gain dial?
My bigger concern is the steep rolloff of frequencies below ~30Hz. The NVX sub is advertised with a frequency response down to 20Hz. The way the kit is wired (tapping into the original sub's lines), it seems (and please correct me if I'm wrong) that we're feeding the NVX sub a signal that has already been crossed over and had the subsonic filter applied that is designed for the stock 8" ported woofer. I don't know the specs of that sub, but I'd guess Tesla designed it to roll off low frequencies sharply at close to the ~30Hz I noticed.
Has anyone else noticed this, and is there a different way to wire it differently to pass those low frequencies to the NVX sub? Or am I way off base (pun intended
) with how I'm envisioning this working from just looking at the wiring diagrams?
