I just ordered the kit from NVX. The group buy coupon code did not work, but somehow someway there was a fluke in their system and they gave me $108 off so I took advantage of it and got the kit shipped for $611. So exciting. I plan to run both subs when I wire it all up in hopes that I can tune the NVX sub to do some of the lower notes that the oem sub is missing. Hoping for a good balance between the 2 subs
In case anybody is having trouble making sense of the wiring diagram, this photograph shows the wires running to the sub. The plug shown goes into the sub.
To the extent this helps anybody else, here is where I tapped the power and ground for the XLC. I used 3M t-taps. I will likely redo this and solder the connections and use smaller wire . I wrapped with TESA tape afterwards.
Some people have asked whether you can remove the NVX sub. You can. Just take out the hex screws and use a panel removal tool to remove the sub. It is not glued in. It looked like NVX put threaded metal inserts inside the mounting holes. I considered swapping the NVX for a JLAudioW3. One issue that you would have to address is the difference in mounting hole patterns. The JLAudio bolt pattern is different. To the extent there were some holes that did not match, you would have to plug those then create new holes for the others. [NOTE: Do not remove the round speaker terminal on the back of the enclosure; the screws go directly into the fiberglass and easily strip out the material]
The GroupBuy started on Feb 12 and was in effect for 2 weeks so over now. Seems they have another discount "SHAWN15" that is even better but who knows how long this will last. $108 is a huge savings.
Does anyone know their tech support hours? I was on hold for an hour and a half before suspecting they went home for the day. I started the call around 5 PM ET.
They are in Louisville, KY so ET zone as well. If you started the call at 5, they likely went home already.
FYI that code is bringing it down 15% so it’s $611. Kind of tempted to buy it, just not sure if it will be worth it to me. The stock system is decent in most regards.
The contact phone number has a 213 area code, which is in Los Angeles. I tried calling at 8:55 AM ET and was immediately presented with a message that their office is closed and to call back during normal business hours. Now it is just a matter of identifying that range. I called back at 9:00 AM ET just now and was presented with the options menu. Update: Wasn't on hold terribly long and talked with Jeremy said that tech support closes at 6 PM ET, so if you happen to be on hold before that, the system will just leave you there. Good to know if you try to do this outside normal business hours.
In all honestly, not sure how the code got applied. It did it automatically so that's why I had to take advantage of the good discount.
I ordered this kit and plan to have a neighbor that seems to work on car audio in his garage do the installation. I have a 2018 LR with the premium audio, and plan to keep running the original sub in addition to the NVX. I want the job done cleanly to where the sub and accessories could be removed and return to stock if necessary. Reading through this thread, it seems that the included kit is incomplete, or at least doesn't include everything that would make the job easier. I saw Posi-Taps mentioned earlier, along with jack nut inserters, not sure if I forgot about anything else. Can someone clarify with specific Amazon links and quantities to order to install this NVX kit specifically?
Part of that was my fault. It isn't a "complete" kit in that if you watch the video, you will see them mention a mounting bracket for the XLCA2 (LOC unit) that goes near the factory amp area. That is something they just fabricated for that install. It is light enough as another user mentioned it can just "float" next to the power amp or add velcro to mount it in the well and out of the way. The VADM1 amplifier will get mounted further up if you mount the same place as the video and there is room in the void below it that you can feel comfortable installing with the self-tapping screws. It seems they have issues from time-to-time shipping with incomplete boxes though. My amp didn't come with the cables and an Amazon review of the VADM1, a customer was missing the terminal block you screw your speakers into, so take account of what you receive. From what I can gather: VADM1 should (probably) come with: 1. 4 pin terminal block (mine was already inserted) for screwing in the speaker leads 2. 3.5 mm to RJ11 connector for the remote bass control (mine was absent) 3. Remote bass control (without LED). Mine came with it, but missing the cable and the XLCA2 came with it so I could adjust the bass if I wanted with this. 4. 4 pin white connector to RCA (required to connect to XLCA2) (mine was absent and they had to ship it) 5. Allen wrench to adjust power terminals 6. Mounting screws XLCA2 should (probably) come with: 1. RJ11 to RJ11 cable for bass control 2. Remote bass control with LED 3. Mounting bracket attachments 4. Mounting screws 5. (2) wiring terminal blocks The wiring kit includes the expected materials so you can see if you have them. I used the remote wire sense, the speaker cable, the power cable, ground cable, fuse, and RCA plugs from it. The power and ground cable already come with one end having a connector. IMPORTANT: Before going to work on the system, find the link to mountain pass performance reset routine and unplug the negative battery terminal and open the contact connector under the seat. Another user pointed out a good idea in removing the fuse in the fuse block before connecting everything and then installing that last. Be sure you have a full 12V battery and/or leave your frunk open. You don't need to use positaps or t-taps if you get a stripper that spreads the insulation. They sell one at ACE hardware for $17 to $20. You make a miltiary splice by spreading the wire to tap into with this and using a small precision screwdriver or pick to make a hole in the wires and feed your wire to insert in there, close the hole and wrap the inserted wire around the exposed area. Then use electrical tape around it and place a few zip ties over it to keep it firmly in place. One mistake I made was trying to go back and spread one further and accidentally clipped some strands, so ended up grabbing the soldering iron for that one. The cost is going to be roughly the same if you use positaps, but you get a tool you can use for quick stripping down the road if you are working on your car or your house. The jack nuts are tricky to get to install. I stripped the one that came with it and if the friction wrench that is coming today doesn't hold it in place, I may just have to resort to zip ties with some padding between the frame and the speaker box mount to keep it from rattling. Tools needed: 1. 10 mm socket and wrench/driver 2. 13 mm socket and wrench/driver 3. wire stripper 4. electrical tape 5. precision flathead screwdriver 6. allen wrench set (I don't think the wire kit came with one for the fuse block) 7. friction wrench (maybe) 8. cheap multimeter is helpful - check continuity between terminals at the plug for the factory amp and test voltages. Placing in VAC and measuring the output of the RCAs from the XLCA2, you will see enough change when music is playing to confirm you are getting output. Material that helps but probably isn't absolutely needed: 1. Tesa Tape 2. utility knife to trim away factory tesa tape carefully and/or scissors. 3. velcro strips to mount the XLCA2 and/or the VADM1. Both are plenty light enough that industrial velcro are probably ok. Note you will want to avoid covering the factory label like I did. Luckilly the box has the serial number on it. 4. 3.5mm to RCA adapter to plug into your cell phone to test the amp if there is no sound If you have a factory amp and want to continue using it: Allyn recommended wiring the speakers out of phase to prevent it from cancelling out the factory sub. In their setup they kept both connected and that is what they did for a sound they liked. I have mine wired this way because I listen to a wide range of music and really like getting that drum hit that the smaller sub will do better at. I think that is about it. HTH Links for items I ordered: Strippers: https://www.amazon.com/gp/product/B000OQ21CA/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 (I saw a generic set at Ace when getting the headphone to RCA adapter) Tesa tape: https://www.amazon.com/gp/product/B00XPDVER2/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 Pick set (in hindsight, the precision flathead screwdriver would've done the job): https://www.amazon.com/gp/product/B002KS1E7I/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 Friction wrench (don't know yet if it works): https://www.amazon.com/gp/product/B00NWJJLXS/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 I saw a specific jack nut insertion tool on there for around $50 but it doesn't come with the mandrel so you would end up spending over $100 just to mount the sub with that.
Good write-up @CoolBuddy. Seems many use positaps or similar but I think the military splice (although more invasive) will provide a more solid connection. As for the jack nut, I'm not sure how much the existing hole needs to be enlarged but I would probably enlarge it incrementally using a round file or carefully using a dremel and keep on checking to ensure a tight fit so it lessens the chance on the jack nut free-spinning.
Good write up CoolBuddy. I will reference it a lot when I go to install mine. Just because I haven't gotten my kit yet and curious, what is the jack nut used for? Is this for mounting the sub enclosure into the car?
Yes If you look at one of the trunk lights you will see a small black circular plug. It will replace that and use it as a mounting point for the sub.
Okay, so I got my jack nut in. Since the instructions referenced installing the 1/4-20 10mm bolt into the jack nut, the replacement jack nuts I ordered were 1/4-20 (ordered from advance autoparts for about $4 for 3. I ordered two packs because their site made it seem like it was ea. I digress. I got my friction wrench in today and it wasn't working for me when trying to do one in the open holding the jack nut with some pliers while tightening the bolt after things spun freely. So It ended up "stripping" the jack nut. I put it in quotes, because it was then that I thought "What if this isn't really a 1/4-20 bolt? I took it down to Ace and sure enough, it was M6 1.0. I bought a 1/4-20 1" bolt from Ace and using the friction wrench and a socket wrench, it went right in. Lesson learned - if you can't easily thread into the jack nut without assistance (to at least get the bolt out/in to be flush with the nut top, there is probably a thread mismatch and go to your local hardware store to get a replacement bolt. Take the jack nut with you to test it.
Can someone that has already mounted their sub chime in on how you got the mount to lineup with the jack nut? The trim holes line up perfectly with the jack nut hole and hole in the rear, but pushing the sub all the way tight against the wheel well side of the trim, I'm still off by a few degrees and a couple inches Solution found: The mounting bracket on the sub had shifted out of place. I was able to rotate it towards the mounting hole.
