Tam
"...Saving face...
I hope he has gotten good professional advice on how to save face with the legal system because subjective testimony is a sure way to lose against objective car logs.
"...Saving face...
“For example, the vehicle will cut motor torque in cases where the accelerator pedal and the brake pedal are simultaneously pressed. Furthermore, current Tesla software uses the Autopilot sensor suite to distinguish potential pedal misapplication events from normal cases when a driver intentionally presses the accelerator pedal. In cases of unambiguous pedal misapplication, the vehicle cuts torque to mitigate the effects of the driver’s error.”
Great in theory, clearly didn't work. At least that's what the Tesla on the sofa tells me.
No, when they saw "cutting torque" they mean cutting to zero. I've had this situation happen several times when pulling a trailer up a hill from a stop. Not only does it cut the torque to zero, it beeps and flashes a warning on the dash display.
...Tesla's systems are designed to prioritize driver input....
I can see this if regen braking is new to the driver (low mileage in these types of cars) or they move about from a non regen vehicle to one with regen. The opposite happened to me the other day. Hoped in an ICE that I formally owned with over 200 k miles of experience but my brain kept wanting it to brake when I lifted my foot off the accelerator. I found myself repeatedly taking corners to quickly and putting on the brakes later than I would normally.Gven the fact Teslas' heavy regenerative braking almost makes the brake pedal obsolete, is it really surprising that one could inadvertently hit the accelerator convinced that he or she was braking?
1. How will Tesla prove that logs have not been modified/tampered with, and there was no bug in the logging software?
2. Shouldn't automatic emergency braking have kicked in, even if full pedal was applied by mistake?
1. and there was no bug in the logging software?
The famous South Korean star has posted on his facebook yesterday, Saturday, 12/31/2016:
Ji Chang Son - 지난 9월10일 저녁 8시에 일어난 일입니다. 저희 둘째 아들 경민이를... | Facebook
A camera in the footwell? I'll volunteer to review the tapes for all of the miniskirted drivers. No, we don't need more technology. Is there a chance the current technology is ever wrong? Sure, nothing is 100% perfect, and these plaintiffs will have a chance to try to convince a jury. They will of course have a mountain to climb.As others have already said, mistaking one pedal for another, or just hitting the wrong one by mistake is not an uncommon problem. Particularly in cars with only two pedals and probably more likely still in a Tesla, where it's not always necessary to use the brake pedal to slow the car.
I've got pretty big feet, so sometimes when I drive a car with a small footwell and pedals very close together, I can end up hitting the wrong pedal too!
I am even prepared initially to give the benefit of doubt to some of the drivers in these accidents, as I'm sure a large proportion of them really do believe they pressed the correct pedal and the car was at fault, not them. In the past, it's been a claim which couldn't easily be disproved, but now more cars are fitted with data logging as standard, the argument develops into a 'human vs. technology' one and common sense goes out the window.
If these "unintended acceleration" claims are going to continue, perhaps some 'proactive management' is needed. A camera in the footwell would be conclusive, but I can see there could be some privacy and personal rights issues to deal with if video recordings are being stored in the data logger.
How about some sort of simple, low cost IR/heat sensor in the footwell which would have enough resolution to detect how the feet are being used on the pedals?
These claimants will always argue 'the computer got it wrong' when confronted with raw data, but if they see an image of their warm tootsies planted firmly on the go pedal, they might be more inclined to save face in a quieter way.
Is he suppose to be doing stuff like that when he's got a lawsuit pending?
At least, venting is very therapeutic
