Picked up the car late Friday.
B piller fixed! looked the same as before, not sure how it is "updated...."
Freshly painted front end and nose cone look great!
However a new set of problems appeared. I noticed #1 as soon as we left the dealership, called our Delivery specialist and informed him. Unfortunately he could not do anything because service was closed until Monday morning.
1) Car has severe shake at highway speeds 60-80mph. At first I thought the tires might be out of balance, but the suspension has been making all kinds of of sounds when driving. Car also does not feel stable. Probably related to not having an alignment and #2.
2)Ride Height. The front of the car is a good inch higher than the rear, the car looks like it is "sagging" in the rear. The left (driver) side of the car is a full 3/4" lower. I measured center of the wheel from the ground to the arch of the car on a flat surface. I checked on multiple surfaces throughout the day all with the same result.
3) Unable to connect to Wifi. Once you connect to wifi it will disconnect and begin "initializing." When the wifi connection crashes, it also causes the bluetooth connecting to crash. This is a never ending cycle until I turn off wifi.
Minor issues:
5) The front right speaker grill is loose or speaker is blown. Certain frequencies make a tin sound ratting noise.
6) Wood trim to left of screen is protruding I pushed it down, but you can still see it is not level with the aluminum screen surround like the right side.
I am going on a long distance trip on Wednesday morning, and now not sure what to do. I will NEVER NEVER buy a used tesla again. Just when you think it can't get any worse it does!
Minor issues:
