davewill
Easist thing to do is to turn off the circuit breaker, unscrew the 14-50, pull it gently out of the box and look at the wiring. Post pictures here if you can't find markings that make sense. It would be easier to see inside the panel, but that requires removing the cover around the breakers, and you shouldn't do that unless you are very sure of your ability to do so safely.Related question for the knowledgeable folks in this thread:
I'm nearing completion on the construction of a new home. I asked them to install a 60A, non-GFCI circuit for later installation of a wall charger (I told them this). I saw that they recently installed a 14-50 receptable at the location where this wall charger is supposed to go, which I assume also means it's going to be on a GFCI breaker (I don't think this is installed yet?). Is there any easy way for me to verify that the wiring they installed is indeed capable of 60A and that I will be able to put in a wall charger later without re-wiring everything? Yes I realize I could just ask them the same question but I'll just say that getting the truth out of these people (rather than what I want to hear) has been quite the challenge. My main worry is that they did a circuit for a 14-50 and called it a day, and that I won't be able to get 48A charging in the future out of a wall charger without re-wiring.
Not an electrician and this is my first time with this kind of thing. Thanks for any advice.
Was the wiring installed inside the drywall, or in conduit mounted on the wall?
You will certainly be able to install a wall connector whatever kind of wire they used. The only question is whether you will end up with a 50a or 60a circuit. One other issue is that for a wall connector, they should have left enough wire to feed into the wall connector. You may have to use a pigtail to finish the installation.
