Another Use for Rear Camera Going Forward
Discussion in 'Model S: User Interface' started by gavine, Jul 25, 2014.
  1. gavine
    gavine Petrol Head turned EV Enthusiast
    Philadelphia, PA
    I'm always concerned with damaging the front lip when pulling in to a parking spot with a curb in front. My wife discovered that you can use the rear camera to aid in this. When inching forward into the spot, look at the rear camera and as soon as you can see the parking lines, you know you're in the spot. Brilliant.
    Here's a picture of my screen once I pulled into the spot. Pretty simple and I hope everyone enjoys using this idea.
  2. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    At least around here, the length of parking spots vary wildly. There are tons the S sticks out a bit in the back even if I pull all the way up. A neat tip, but I'd be concerned about unknowingly pulling into a shallow spot.
  3. jthompson
    jthompson JThompson
    Locust Grove, Virginia, United States
    @gavine: Great tip - I will have to try that! Thanks!
  4. gavine
    Philadelphia, PA
    We haven't seen that issue in NJ. Maybe there is a regulation here that requires spots be a certain depth?
  5. AnOutsider
    AnOutsider S532 # XS27
    Agreed. I tried this once or twice, but spot widths and depths vary greatly (is there a standard?), so in reality, it's only useful if you know the spot and that the lines match up with what you're aiming for.
  6. PeterK
    PeterK Model X & 3 Owner
    Cambridge, MA
    I use it when I drive through one spot to park facing out on the other side - as soon as I can see the painted dividing line in the camera, I stop.
  7. AnOutsider
    Yes. that also works really well for backing into a spot.
  8. pete8314
    pete8314 Vendor
    DFW, ex UK
    Which s/w release has those handy arrows? Just kidding :) I use the b/u camera for the same thing, I also know I'm far enough into my garage when I can see 1 full tile behind me.
  9. GoBlue88
    GoBlue88 Member
    Carlsbad, CA
    Yep. Use that all the time to make sure I'm in the parking spot far enough but not too far.
  10. Science->Truth
    Florida
    Like many, I also worry about scuffing the lower front on parking bumpers. A front, downward tilted camera would be a great option. Its impossible to judge exactly horizontal approach distance, or the height of the curb or bumper vis a vis the low Tesla. With a previous car, I once parked over a parking stop with no problem, but when I backed out, two rebar were sticking up just a half inch, but they hooked under the plastic lower bumper piece and ripped it right off.
  11. ABVA
    ABVA Member
    Northern Virginia
    I usually "Back in" to a parking spot, so that back up camera automatically comes on and very clearly shows where the curb is. Secondly, rear of the car is much higher compared to the front end and that prevents scuffing. Other times I have used the b/u camera while driving which eliminates most of the blind spots.
  12. pete8314
    pete8314 Vendor
    DFW, ex UK
    That happens a lot (with the rebar), though I guess it's more of a North America problem, most spaces are not like that elsewhere, but the curbs can be much angrier, my old street had granite curb stones, and were brutal to rims. You never forget that crunching sound!
  13. flashflood
    flashflood Member
    Los Altos Hills, CA
    I also use the rear camera while driving. Provides perfect visibility into the blind spot.
  14. Gabzqc
    Gabzqc Member
    Finland, Helsinki
    great simple idea. Simplicity rules the nest as always.
  15. Great Dane
    Great Dane Member
    United States St Pete FL
    great idea
    tried it today
    and it worked
    if you park at the same places all the time
    you can get used to the length of the parking lines and do it
    backing in is also the preferred way but sometimes the drivers door will face a wall and you cant get out
  16. ABVA
    ABVA Member
    Northern Virginia
    You might want to look at artsci's solution, here is the link:
    Front/Rear Camera Touchscreen Switch Kit - SOLD
  17. pete8314
    pete8314 Vendor
    DFW, ex UK
    Which would also be relatively easy to achieve in software, to provide a drivers blind spot aid. My previous car (A5) used the rear camera for blind spot detection, but I think it also had sensors in the mirror housings.
  18. artsci
    artsci Sponsor
    Timonium, Maryland
    Not so easy to achieve in software as you might think. WhiteP85 spent two months designing the circuit for the camera switch, and this was just to switch between a front and rear image on the touchscreen with two Tesla cameras mounted on the the car -- the stock Tesla camera on the rear and another mounted on the front.
  19. pete8314
    pete8314 Vendor
    DFW, ex UK
    True, 'easy' is the wrong word, but I would think it would be do-able, for Tesla, at least?
  20. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    I tried gavine's trick and it worked perfectly. Thanks!
