Another way to change nav/map orientation...
Discussion in 'Model 3' started by sreams, Nov 6, 2018.
  1. sreams
    sreams Member
    Sacramento, CA
    Sorry if this has already been mentioned or if people found it to be more obvious than I did.
    After the V9 update, the icon used to change the nav orientation moved all the way over to the right edge of the screen. I used that icon a lot and missed having it closer to the driver's seat.
    I recently discovered that you can touch the top part of the directions list, and it will toggle the nav orientation between full-trip and whichever zoomed in mode you used last (North up or direction of travel). No need to reach over to the other side of the screen anymore.
    • Informative x 8
  2. BillO
    BillO Member
    San Francisco, CA
    Thanks for that!
    Now I just wish they would move Homelink to the left side. It’s quite a stretch way over there on the right...
  3. Msjulie
    Msjulie Active Member
    Monterey Bay Area
    Agree but you can make it automatic - it can open/close the door based on the car's proximity... but I choose not to just cause I guess..
  4. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    That is a dangerous option if you share a double garage with someone and you ever get home at a similar time
  5. VT_EE
    VT_EE Active Member
    Maryland
    This why I turned it off. Sucks when the door is already open and you drive up.
