Anti-theft solutions for UMC in public garage?
Discussion in 'Model S: Battery & Charging' started by LonghornDub, May 21, 2014.
  1. LonghornDub
    LonghornDub Member
    Texas
    I live in a condo with a large shared garage, and while it's a pretty safe and secure building, I don't want to leave my UMC sitting in the garage all day while I'm at work with the car. One solution would be to unplug it and take it with me every day, but I've been told that repeatedly plugging/unplugging from a 14-50 outlet will wear down the outlet over time.
    Is anybody aware of any solutions to help secure the UMC while the car is gone? My outlet is installed on a large cement column with room above and below it, so feasibly I could install some sort of secure device to "lock in" the UMC when I'm not there. But I have no idea what type of device I should be looking for.
  2. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Don't worry about unplugging each day if feel you need to. Outlets at RV parks are plugged/unplugged all the time, and if it does wear out it's really cheap to replace.
  3. markb1
    markb1 Active Member
    San Diego, CA
    Here's an older thread on the topic:
    Securing the UMC in my public parking spot?
  4. Ven Rala
    Ven Rala Member
    Montgomery County, Md
    I have been plugging/unplugging my 14-50 at work and home for the past year and 23,000 miles without a problem
  5. markb1
    San Diego, CA
    If the connection is loose, the car should detect a voltage drop on stop charging. But if for some reason it keeps drawing current and arcs, it could burn your house down. I'm not sure it's a very likely outcome, but I would be careful, anyway.
  6. qwk
    qwk P130DL
    Same here.
  7. Kalud
    Kalud Active Member
    Montreal, QC
    Not always possible but I usually try something like this. You can also wrap the cable around and lock...
    Pic from last winter.
  8. LonghornDub
    LonghornDub Member
    Texas
  9. tga
    tga Supporting Member
    New Hampshire
    I still have yet to see anyone post any PROOF of this claim. Until then, I'm inclined to chalk it up as Tesla forum rumor/hearsay.
    I have looked for rated number of insertions/removals for Leviton and Hubbell outlets, to no avail.
    Personally, I wouldn't worry about it. I'd pay attention if the outlet seems to "loosen", and I'd occasionally check it for heating while under load (which is probably not a bad idea, anyway).
  10. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    I'm with many of the people here. Just plug/unplug the UMC from the wall. If your outlet does eventually wear out it is such a easy cheap fix to replace it. Not worth worrying about.
    Now if you wanted to say taking your UMC with you every day is a hassle, that is a different question.
  11. LonghornDub
    LonghornDub Member
    Texas
    Well, it certainly is a hassle, but I'm not sure it's anymore of a hassle than, say, locking up the cable every day.
  12. markb1
    San Diego, CA
    You don't necessarily have to lock up the cable, though. You could rather come up with something that locks up the adapter end, and leaves the cable free. Depends on how much you're worried about someone cutting off the cable.
  13. LonghornDub
    LonghornDub Member
    Texas
    Yeah, this is the ideal solution if I can figure out a way to do it without spending unnecessarily. The cage idea posted in the other thread (linked above) actually seems like it could accomplish that.
    I'm not overly worried about somebody cutting the cable.
  14. invisik
    invisik Supporting Member
    Minneapolis
    PERFECT, I'm going to copy you. :)
    -m
  15. KenN
    KenN Member
    North Vancouver, BC
    Not sure if this is an option for you, but this is what I did at home;
    There's a slot cut into the bottom of the box, too small to fit the adapter (if one were able to unplug it, the door only gives about 15 mm clearance to the back side of the adapter). A special key is needed to open the door of the box. Bought the wall hanger from Tesla.
  16. LonghornDub
    LonghornDub Member
    Texas
    Looks great. Where did you get the lockable box?
  17. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    yea i like this idea too. good job. i'll probably duplicate this.
  18. KenN
    KenN Member
    North Vancouver, BC
    The box should be available from most electrical suppliers, most important is to get a NEMA 3R rated box. That will give you a weatherproof enclosure to keep any water out. I can measure up the box dimensions when I get home tonight if interested.
    For the install, we have conduit running just above floor level inside the garage, then bend up, then out through the wall of the garage. I could have put the 14-50 outlet inside the garage but didn't want to be bothered with opening/closing the garage door all the time. This setup lets me leave the UMC outside, easy to access when I want to plug in. I'm actually not overly concerned about theft, but we do get the occasional small groups of drunk teenagers on summer nights, so didn't want to leave the temptation for unplugging as a little "joke".
  19. invisik
    Minneapolis
    Can you stuff the module thing on the UMC into the box as well? Looks like there might be room. Kinda weatherproof the whole thing then with only the cable coming out of it. Great idea!
    -m
  20. KenN
    KenN Member
    North Vancouver, BC
    I imagine you could, just by mounting things so the 14-50 outlet is up near the top of the box. The UMC module is weatherproof though, so I didn't worry about it. Also, hanging as it is, I can see the green light strip on the UMC from my living room window so easy to confirm charging!
