Just thought I would post my experience with a S out of warranty and 156k miles so you newbies would be ready.
First the door mechanisms will fail. Little gear cost $1.20. Or the wiring harness between micro switches wires will break off. $68 for new harness. I replaced 3 door mechanisms so far.
Window regulator will stop. Cable rusted and broke. Changed 2.
Front rotors and pads were very easy replacement. Put on drilled and slotted rotors, ceramic pads. Great improvement.
Front hub bearings will start to growl in slow turn. Very easy to change.
Tie rod ends were a pain, finding tools took longer than replace.
I have got to change bottom left ball joint, lose, won't pass front end alignment.
MCU touch will leak out. Mine has been leaking for 2 yrs, about 1/2 inch all around. I think I will pay SC to do it. My patience wont stand taking dash all apart. Cost $1500.
Main instrument panel is leaking. About 50% gone. I dont see any reason to change it yet. Everything is working.
I have had cooling issues. Found out pump 2 was bad. Changed it in 5 minutes. U need hose clamp pliers to shut off water.
I forgot. Car wheel alignment can be done at any shop with a Hunter Hawkeye Elite. Verified by Hunter. That's how I found I had lose tie rod end and bad ball joint. He could not get wheels to stay in place.
Got new motor and gearbox in March 2019.
I've ordered both rear axles. Time for CV joints to go bad. I think I have on now. Slight vibration at 72-76 mph. Not tires, changes all 4, still have vibration.
I will change 12v battery soon. It's old. If it dies you are dead on the side of the road.
