Deuce24
I’m getting it on the four entry door sills and on the rear bumper where it’s flat (that luggage tends to scratch).Are you getting clear film on the bumper too?
My bad, I meant the front bumper. I was thinking of getting it on the rear bumper where it’s flat to avoid scratches too. Take some pics of that area afterwards when you have time.I’m getting it on the four entry door sills and on the rear bumper where it’s flat (that luggage tends to scratch).
Not planning on it, pretty spendy. Getting it tinted instead. My uncle does paint repair and whatnot so if I get any knocks in the paint I can get the paint repair and a hefty discount.Are you getting clear film on the bumper too?
I have a dragy gps module if you want to borrow it for accurate times?I posted on Reddit with a video and some info! r/teslamotors - Model 3 AWD 0-60 runs!! (non-performance)
headers do not show for me on the data tab so I'm not sure what to type into the boxesFYI, elsewhere we started a sheet to track AWD (and P-AWD) orders. Feel free to add your order to the Data tab to get a better sample size.
We're getting some good summaries by region, wheel type, etc.
Is Slip Start on or off? Try to activate it so the VDC doesn't reduce power at launch. Should get quicker times if the tires can slip a bit.I posted on Reddit with a video and some info! r/teslamotors - Model 3 AWD 0-60 runs!! (non-performance)
Please pick a safer place to do this.....
That's great, thanks! But this isn't very accurate. By design speedometers tell you that you are going a little slower than the actual speed. Looking forward to an AWD run with Dragy so that we can compare it to the AWD Performance Dragy videos.
I am hoping for some giggling and giddiness when the pedal was floored. A true indicator of acceleration rate!
Oooo, I'll give that a try next time I'm out and in a better/safer place.Is Slip Start on or off? Try to activate it so the VDC doesn't reduce power at launch. Should get quicker times if the tires can slip a bit.
Hah, I was trying to remain quiet. It definitely pulls the squeals out of you though!I am hoping for some giggling and giddiness when the pedal was floored. A true indicator of acceleration rate!
I'll PM you.I have a dragy gps module if you want to borrow it for accurate times?
