The reasoning here is BS. And here's my data points:
1. Just above we see
@boonedocks' 100D produced 2/17 (with old motor configuration, same as 90D) is eligible for uncork. So it's not an issue with the motor.
2. Regarding battery packs limits:
Both 90D and 100D packs are 400V. This is 1.142X the voltage of the 75D pack (350v), some rough math tells me that if the uncorked 75Ds in
@Krash 's metric summary are hitting 368KW, then scaling that X 1.142(which maintains the same current limits), the 90D pack should be able to hit 420KW.
420KW is coincidentally in the range of what the uncorked 100Ds are putting out...
Upgraded performance Metrics Summary
Side note: I've also seen that my same 90D battery P/N (1088790-00-A) has been used in P90D configurations. (Which have much higher amperage limits).
Source:
2016 Model S P90D - $92k
