I'm not a wheel / tire expert so sorry if this is a silly question.
Would there be any advantages to replacing a 235/45R18 setup with 235/40R19 with the same type of tire? Since they would be the same width I wouldn't expect any traction improvement because the contact patch would be the same, right? Would there be any handling improvement due to the stiffer sidewall? Since the contact patch would be the same size does the mean the energy efficiency would be the same? Since the overall diameter would be virtually identical there should be no issue with speedometer error or tire clearance, right?
I can think of a few disadvantages of the taller wheels
Thanks!
- 19s would be a bit heavier than 18s even in the same width so may / will negatively impact acceleration and handling
- Slightly harsher ride and slightly more prone to damage due to lower sidewall
- More epensive
- Might be more attractive in side view
Thanks!
