Any advise on a fix for this?
Discussion in 'Model X: Interior & Exterior' started by Maaz, Oct 8, 2017.
  1. Maaz
    Maaz Member
    Torrance
    just noticed this today, don't know how it happened but I'm just wondering if theres a way to fix these indentions in the leather, or if tesla has a way to fix or replace this part under warranty?
  2. Hans Allis
    Hans Allis Member
    Leersum, Netherlands
    Ouch.. don't believe that's leather though, rather some kind of plastic. Hope you can get it fixed.
  3. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    It’s definitely plastic but what would do that, heat or mistreatment in application?
  4. Maaz
    Maaz Member
    Torrance
    Sigh no idea. I’ll make an appointment at the service center ASAP and will find out what to do I guess.
  5. boaterva
    Keep us informed! That is really a defect, so, no way they won’t fix it.
  6. Maaz
    Maaz Member
    Torrance
    Took it to the service center to see if I can get it fixed along with a laundry list of small issues I’ve had for a while now, they said it looks like someone dug their nails into the rubber part and because of that they can’t replace it under warranty as a manufacture fault. They said if I wanted it fixed they would replace the entire door panel which was quoted at $1,189 parts and labor.
    Sad because I have no idea who could have done this. Anyone know of a cheaper solution for a fix? doesn’t have to be perfect.
  7. Lbkmxp100d
    Lbkmxp100d Member
    Lubbock, TX
    Definitely looks like something or someone has indented that and not a defect. Just my .02
  8. cartwright
    cartwright Member
    San Diego
    Any chance someone wearing a watch slid across the panel and it grabbed the material? I had a fluke scarring of my leather steering wheel (Lexus) from my wedding ring. It someone caught just the right angle and marked it.
  9. verygreen
    verygreen Curious member
    TN
    This whole panel seems to be prone to some weird damage.
    Here's what I found on mine. I have no idea how that could happen since it does not touch anything at any time. Looks like some sort of a tool imprint form the past Service Center visit?
    I did have them replace my steering wheel because they managed to scratch it on one of the piror ones too
    BTW the other doors are not much better, I had a bunch of problems and torn leather there too (some still not fixed - waiting for parts for over 2 months already)
  10. Krazaak
    Krazaak Member
    Charlotte, NC
    Not to make light of your situation, but that was my first thought as well. It looks like you've been flooring it and scaring the crap out of your passengers.
    It might be worth taking it to some sort of interior or upholstery specialist. Dealerships (yeah yeah, service centers) are good at replacing parts, but they rarely bother to learn tricks to actually repair a part.
  11. chilman408
    chilman408 Member
    Yep cheapest way is to wrap it with a more compliant material
  12. Jimmy 1
    Jimmy 1 Member
    Sarasota, FL
    Try to steam it.
  13. Dann@OptiCoat
    [email protected] Former Vendor
    San Diego, California
    Looks like you showed your passenger a white knuckle ride! Could be a super simple repair where heat could be applied and then pressed with a grain pad, and look amazing. Tricky and time consuming. But if there is penetration it will need to be filled grained cured and dyed for proper repair. I would search out a detailer who does leather and vinyl repair and has some good reviews.
