brkaus
properly configured load sharing set to 60a breaker (48a charging) should be OK on a single breaker that is split by splices. Wiring for each needs to support 60a.
That used to be the standard process per my electrician.
However, my electrician as of now, the only way he can do it now is with two circuits at 60a each.
- They can be 60a each to the main panel.
- They can be 60a to a sub panel, and then two 60a circuits from there.
In both of above cases, 60a would still be used for the load calc due to load sharing.
- it is not required that the sub panel be on a 100a circuit. 60a is fine.
- this example can be scaled to any number, based on the capacity of your house.
he said splices are still ok in his mind, but no longer allowed. He did not tell me why the change.
source of info - I had a quote several years ago to have a second WC2 installed. I just had the quote “refreshed” last week. Of course, wc2 requires comm cable between the two and WC3 uses wifi (latest firmware), but he said that was effectively no different.
