Any experience with 17" or 18" rims/wheels?
Discussion in 'Model S: Driving Dynamics' started by FVO, Nov 11, 2016.
  1. FVO
    FVO Active Member
    Hi i was wondering if there is any experience with people trying out a smaller rim size? (and perhaps a different tirewidth) I can imagine that with a higher sidewall, to maintain the same circumference, comes lesser crispyness (handling) to take a corner but does come more comfort. But disadvantages as well.
  2. Zaphod
    Zaphod Galaxy President (former)
    Austin, TX
    Not sure, but smaller diameter wheels might have clearance issues with the brake calipers. The Brembo calipers Tesla uses are pretty big. That would be the main concern to check on.
  3. FVO
    FVO Active Member
    That's right, that is one of the things that i'm wondering.
  4. Roadrunner13
    Roadrunner13 Member
    Montreal
    It would be an issue at least with the front suspension arms.
    On my non-OEM 19" wheels, the calibrating weights had to be put 'out of harms way' else it would be ripped by a bulge on the bottom of the lower arm.
    (Don't remember the exact part name, but if you look at lower suspension arm through the wheels, you should easily see there's no clearance for smaller wheels!
    Sorry.
  5. FVO
    FVO Active Member
    My Tesla is having a sleepover this weekend (needed a hitch for the weekend...).
  6. Fiver
    Fiver Active Member
    Utah
    if I recall from earlier threads, the biggest hurdle is the large brake calipers don't fit inside the smaller rims.
  7. PaulusdB
    PaulusdB Mayor Gnomus Vintage Limb
    Europe
    Elsewhere on TMC some owners report using a 18" steel BMW rim with a very narrow tyre as spare.
    Because of the narrow tyres and low ET these rims stay clear from the suspension parts.
    Not advisable for day-to-day use; insufficient grip.
  8. PaulusdB
    Europe
