Yes, that was probably my Video, you’ve done your homework
I think if there is an air leak then “wind” might dominate. Currently for me, tire noise dominates. And with the OEM Pirelli Performance snows. Tire noise is quite good. I’m very tempted to switch to 19” non staggered setup for summer tires because it’s so good with the winter setup. With 20” staggered setup the options are limited. Since I am running snow tires and COVID limited driving it’s gonna be a long time.
The Jeep Summit I had with acoustic glass and active noise cancelation was extremely good. So I had a fairly high standard I came from. I’d say with the winter tires it’s 90-95% as good as the Jeep was and I’m satisfied.
I don’t blame the vehicle if the summer tires are not quite as good noise wise. I should be able to fix that. Also because tire noise is dominate (for me) if you are on fresh smooth pavement, it’s an absolute dream. Also I’d be curious how quiet some other ICE cars would be with the same amount of glass.
Also when I did fix the drivers windows I cleaned up lots of small gaps on the door liner (not sure what to call it). I’d like to do all 4 doors. I’m not sure how much that helped.
BTW I’m not an +85mph driver. I tend to rarely go above 70mph. Higher speeds can be more challenging.
One complaint I do have is hands free noise cancelation is poor. It seems a lot better lately. Not sure if it’s because of winter tires or they actually fixed something. But this past summer folks were complaining they could not hear me.
I also completely respect your questioning this topic. I did a lot of investigating on the model 3. But still went ahead thinking it would be ok. It really wasn’t. That’s why I said to drive a few X’s, in hopes you can see what a good one sounds like.
Good luck.
