Any idea where to install autotoll on Model X?
Discussion in 'Hong Kong' started by Pandachief, Feb 8, 2017.
Tags:
  1. Pandachief
    Pandachief Member
    Hong Kong
    Any idea? I tried the entire windshield and seems not working!
  2. andee
    andee New Member
    Hong Kong
    Someone puts it at the driver side lower corner, and it works.
  3. canon
    canon Member
    Hong Kong
    Anyone knows if the new "white" tag is better than the old "grey" tag. I know that the white tag is much smaller.
  4. arijaycomet
    arijaycomet Member
    Cleveland, Ohio
    See above-- this image link shows you where to appropriately place RFID transmitters in a Model X
  5. Pandachief
    Pandachief Member
    Hong Kong
    Thanks all! I tried and seems it work almost anywhere inside the windshield. The service center confirmed that it is a lot more forgiving for Model X when compare to Model S.
  6. frangus6
    frangus6 Member
    Hong Kong
    Hi Pandachief, where did you end up mounting your tag? Care to share some pictures?
  7. larmor
    larmor Active Member
    Westlake, TX
    (Pls ignore if repetitive) Similar issue here with fastrak on toll roads in CA. I kept my fastrak in the driver's side door pocket. When the toll reader comes, i move my arm out of the way and it beeps. Note, receiver needs to face opposite of what would normally work on a window. I know it's weird, but it works, and keeps the window clean....
  8. Pandachief
    Pandachief Member
    Hong Kong
    Lower right of driver side like most other cars!
  9. HKSpud
    HKSpud Member
    Hong Kong
    Can we do something like the model s and have it somewhere in the front trunk near the old nose cone? I bought one of those auto toll silicon sleeves for the auto toll but the suction cups are useless and I'm not hugely keen on the crappy double sided sticky tap approach... anyone else with a better approach?
  10. HKSpud
    HKSpud Member
    Hong Kong
    I wonder whether this would work for HK auto toll transponders:
  11. canon
    canon Member
    Hong Kong
    Why you said the suction cups are useless? Did you try putting the tag on the flat surface immediately below the lower hand corner of the glass instead of sticking it on the glass?
  12. HKSpud
    HKSpud Member
    Hong Kong
    No I didn't try that but that flat surface is like a speaker grill right? The suction cups won't adhere to that and it'll just fly around...
  13. flyingbathtub
    flyingbathtub Member
    Hong Kong
    I got inspired from the nose cone instllation for older Model S and installed the tag in the gap between the frunk and the bumper, and I can confirm that it works really well (3 out of 3 tolls just now).
  14. Frogwheels
    Frogwheels Member
    Hong Kong
    I can confirm this works for me as well. I placed it the top right corner of the windshield, over the drivers seat. Perfect location, doesn't impair visibility at all and not a hassle to install.
  15. garethmchau
    garethmchau Member
    Hong Kong
    too ugly above drivers head. agree with Pandachief bottom right corner on driver side out of sight is best.
  16. flyingbathtub
    Hong Kong
    Or hide it in he frunk/bumper gap. Easy installation and 100% out of sight.
  17. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    Autotoll just replaced all my tags with the new stick-on-label type. Much simpler, and no battery to worry about. Also, supposedly works through Tesla windscreens, and the added bonus is no deposit needed.
    Only drawback is that these are not compatible with the old big-chucky-box style tags - so won't work with car parks and clubs that need those. But, they work fine in the tunnels.
  18. Optic
    Optic Member
    Hong Kong
    Just requested for mine. They say to install it behind the rear view mirror where the dots are. (for Model X)
  19. flyingbathtub
    Hong Kong
    Any pictures markwj?
  20. HKSpud
    HKSpud Member
    Hong Kong
    Interesting... can you post a picture to show what it looks like please? Cheers
