Scopes are not that expensive. A quick search on Amazon turned this up:
https://smile.amazon.com/KinCam-Inspection-Waterproof-Semi-Rigid-Smartphones/dp/B07W5K92RL
Sucks dropping your nuts in your car. Can I suggest protecting your nuts more carefully so they don’t drop. But I think in your case, they’re lost forever....a dropped M&M peanut into a hole under the driver's seat, apparently there is a large open area under the floor about the width of the car and 3 or 4 feet long.... NOW, every time I turn, accelerate or decelerate I can hear the M&P rolling around under the floor, IT IS SOOO ANNOYING!!! My initial thought is, take it to a supercharger and let the battery warm up to melt it but not sure that is the best solution from a sanitary perspective. My other thought is to take the drivers seat out to get a better look at it but it will most likely be pushed to one of the extremities of the cavity it is stuck in.
Until I read the rest of your post, I thought you were going to say the fossilized Cheerio stayed there for years (from your daughter's grade school days through college).I had a fossilized cheerio attached to a hard gob of glue rolling around inside an air duct beneath the driver's seat. This dated from the days when my daughter used glue guns and cheerios to make school projects (and she is now graduating college).
It rolled. It rattled. It drove me nuts.
I had a quarter rolling around inside that vent. If you contort your hand JUST SO, you should be able to reach it. The vent's wide enough for an entire hand to fit.
Apparently it's a good-luck tradition here in the northeast to throw change into the backseat of someone's new car. I had someone (who shall remain nameless) who insisted on doing so, even after I asked them not to... shot a bullseye right into the floor vent.
Like a Snickers commercial -- "Not going anywhere for a while?"
Given the OPs assumed age (old enough to drive a car), I'd think his nuts already have dropped.Sucks dropping your nuts in your car. Can I suggest protecting your nuts more carefully so they don’t drop. But I think in your case, they’re lost forever.
Only 4 hours too late... Any ideas how to retrieve... (don't laugh)A mouse would probably eat the M&M, but then you will need to figure out how to remove the mouse.
Maybe add a cat once your sure the M&M is devoured?
Since you're getting as many jokes as helpful responses, I'll make a suggestion based on what I just saw when changing the cabin air filters. If you follow the DIY instructions to take the carpet panel off of the center console footwell on the passenger side, you'll see an opening toward the bottom. I'm sure you can remove the panel from the driver's footwell too. I think this may give you access to the space under the floor. I don't know if a vacuum hose would fit in there, but an endoscope would for sure.
(Screenshot from:)
