Any Issues Using GFCI Breakers for Charging Circuit?
RandomSample
19
11
Hi Folks,
Any issues with having their home charging circuit on a 30 or 40 Amp GFCI breaker?
I understand that there are longer charging times on these lower amperage circuits.
I'm still in my planning phase. This circuit/outlet will be in my garage.
Thanks in Advance,
GHammer
What a long strange trip its been.
Feb 1, 2016
877
1,947
Wren, Oregon
Despite what NEC says, people have reported issues with having charging circuit on a GFCI. When the connector tests for ground it sends a small current that can trip the GFCI on some breakers.
marco33
23
13
Pa
Before I installed my 220, was using a 20amp 110 GFI. in the three week period the GFI tripped three of those days. One day it tripped like three + times in a row, that was very annoying as the reset was in the basement.
Reactions: doghousePVD
theeskimo
61
64
Vancouver Washington
According to the electrician who did my NEMA 14-50 install who has done “countless” other Tesla specific installs in my area, Square D breakers seem to be more tolerant and cause fewer ground faults than any other brand of breaker he had used in an install. So far I have had zero trips while maxing out my mobile connector.
Reactions: rokitnerd
ElectricIAC
Devil’s Advocate
Dec 31, 2019
2,219
549
DFW
Hi Folks,
Thanks in Advance,
Our 14-50 has an Eaton GFCI box which regularly made the Gen2 UMC lose its ever loving mind: My solution? Buy Gen1 UMC and enjoy 40A charging.
I’m aware this isn’t *ideal* but after giving up trying to find a 14-50 plug HWPC or at least a modified one this was the next best thing. For your setup what’s truly stopping you from just going 50A?
Scrannel
146
59
Malibu, CA United States
I believe California is on the 2014 NEC. Thus, my guess is, GFCI breakers are not required. The Mobile cord -- and I think all Tesla cords -- have some sort of GFCI built in. Thus, as others have pointed out, the cable can cause an external GFCI to trip. Just from what have been reading in several forums. I am not an electrician.
Reactions: Gasaraki
RandomSample
19
11
Thanks for the info everyone. My first preference will be to go for a 50A circuit in the garage. However, it has to be GFCI because it will be serving a dual purpose besides charging a Model 3.
doghousePVD
My grandfather’s car
Dec 3, 2018
587
472
New England, USA
The NEC code is complicated and appears to be inconsistent. Verify if in your jurisdiction you actually need GFI for your alternate use.
I believe stoves never need GFI. Depending on which NEC is in force most RV plugs (14-50) do not require GFI.
My understanding is all EVSE have built in GFI.
Reactions: Runt8
GPinzone
324
172
Ronkonkoma, NY
The 2017 NEC is generally interpreted to REQUIRE GFCI on EVSE circuits, so no, it’s not an issue.
Are you implying the 2017 NEC was well thought-out? The GFCI requirement was thrown in at the last moment.
BTW, if you tell an electrician you want a NEMA 14-50 outlet installed and don't say why, then what?
rokitnerd
35
7
New Jersey
Now that it's been 9 months do you still have no issues with tripping?
valaeyron
241
129
Virginia
Hi Folks,
Thanks in Advance,
I have a 240V / 50A line (shared between the unused outdoor hot tub and beloved 14-50 in the garage) on a GFCI. Never an issue...
Reactions: ElectricIAC
