Any one have the trunk opening dimensions ?
Discussion in 'Model 3' started by instigator, Jul 31, 2017.
Tags:
  1. instigator
    instigator Member
    FL
    I am looking for actual opening dimensions and / or better yet what size rectangle will fit in the trunk given the lip and inside wheel wells. Any photos / videos would be appreciated as well. ( i.e. will it fit my i14 Hobie kayak.. )
  2. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
  3. chronopc
    chronopc Active Member
    Also has anyone been able to confirm that the back seats fold all the way down?
  4. Thomas Edison
    Thomas Edison Active Member
    Portland-ish
    Do you mean flat and flush with the trunk floor?
  5. gaswalla
    San Diego
    yes... also in that article I reference
  6. chronopc
    I would like to confirm that the picture below is accurate.
  7. chronopc
  8. Thomas Edison
    Portland-ish
    Funny you posted that. I was asking because I too want to confirm that and that's why I was looking for more detail from you.
  9. instigator
    instigator Member
    FL
  10. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Someone needs to borrow Franz's car again. :D This is the sort of thing Bjorn or some other real tester needs to do, wring the car out with questions we care about....
  11. boaterva
    From the picture above, looks like it's not perfectly vertically rectangular, if you see what I mean.... that top corner where it curves at the lid's edge may be the widest part?
  12. DR61
    DR61 Member
    Gold River, CA
    If the opening is really 18.5"x42" (47x107 cm) and 81" (206 cm) bed length, it will fit my road bike without removing front wheel - sweet!
  13. boaterva
    There was a comment in the Motor Trend review that Franz is an avid cyclist; I bet that's already been tested!
  14. North75
    North75 Member
    MA
    I suspect that the 18.5" was measured from the upper rim to the lower on an angle. The true vertical dimension would be less.
    I measured the opening on my 2006 BMW 325xi for comparison and the Tesla is bigger in both dimensions by a few inches.
    I've gotten some reasonably large items in the trunk with the seats down on my car, although it can take some effort figuring out how to maneuver oddly shaped items over the bottom of the opening.
    I'd say this will be fine for "most" people trying to move normal sized objects.
    Hopefully you will have, or have access to larger cars when truly needed.
  15. instigator
    instigator Member
    FL
    yes .. I am looking for the vertical hight trunk bed clearance to below the rear window opening, not the diagonal opening dimension.
  16. montreid
    montreid Member
    san diego,ca
    Also the depth is important for carrying luggage and boxes from the airport when F+F visit. It's nice that they give seats down dimensions and width, but a simple dimension of cube would be nice to have
  17. BluestarE3
    BluestarE3 Active Member
    Norcal
  18. instigator
    instigator Member
    FL
  19. davedavedave
    davedavedave Member
    NoVA
    I've loaded up a few cars where I couldn't fit a guitar amp into either the trunk or the back seat - putting me into a serious panic before a gig! I've sworn that I'd never buy a car that had that problem, but now I'm a little nervous about the model 3. I hadn't thought about that 18.5" measurement being diagonal!
    I would love to get more clarity on the trunk dimensions too.
