Any one tried THE LAW Front license plate?
Discussion in 'Model X: Interior & Exterior' started by tonni83, Aug 12, 2017.
  1. tonni83
    tonni83 Member
    Seattle WA
  2. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    Yes, I use that mount for my front plate on my X, with AP2 hardware. Zero problems.
  3. tonni83
    tonni83 Member
    Seattle WA
    Awesome - thanks for confirmation. I will probably order one.
  4. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    For another data point, I've seen many threads about it and ordered one for my new (ordered) X. The 'Now You Know' guys have a video about it, also, if you care to look it up. It's also a good idea if you are going to get the car wrapped.
  5. Kurt'sX
    Kurt'sX Member
    San Diego
    I installed "the Law" bracket. Pretty easy but the wrench provided didnt work very well, the angles arent really good for tightening the bolts. I got out my trusted socket wrenches and used a flexible shaft for reaching into the grill and getting things tight. Also be careful not to over tighten, as the bracket is attaching to a plastic grill beneath the bumper. If you get too much torque the plastic grill will twist or probably break. (this is also a concern if you ever have somebody bump your front end.....the grill looks very susceptible to damage should you get bumped even lightly)
    I also dont like the plate on the front, so I use some hand tighten nuts and bolts to remove and replace the plate if I need to use street parking or drive to places I know the front plate laws are more strict. San Francisco and Los Angeles allow the parking enforcement folks to write tix for no front plate, so you have to watch out in those neighborhoods. Otherwise, my front plate remains in my frunk and the front view of my X looks pretty clean.
  6. Padelford
    Padelford Supporting Member
    Seattle
    I've got one installed. It was a little tricky getting the threaded holes to line up with the holes in the license bracket thru the plastic grill, and I'd recommend getting the bolts started then tightening them all at the same time. Prying a little bit with a long screwdriver to get things lined up also helps.
  7. vandacca
    vandacca ReActive Member
    Hamilton
    I concur with @Kurt'sX assessment. Fairly straightforward to install, but the provided allen key isn't quite long enough for an easy installation. If you have a longer allen key, it would help a lot.
    I installed about a year ago, so not sure if they have rectified the issue since then.
  8. kev1n
    kev1n Member
    Bay Area
    you either rock the front plate or you dont, why pay $125 to relocate it a bit lower? kind of pointless if you ask me
  9. vandacca
    Hamilton
    One advantage of "The Law" is that you do not need to drill holes into the bumper. This is why I decided to go with it.
  10. kev1n
    kev1n Member
    Bay Area
    the OEM bracket isnt screwed in, its held to the bumper by adhesive
  11. Kurt'sX
    Kurt'sX Member
    San Diego
    I did it for two reasons, I didnt want to drill or glue anything to my bumper, but I still wanted a bracket to attach my plate should I need to display it. This bracket is nearly invisible when the plate isnt attached, but allows for quick install if I happen to be in an area where front plates are required. I attach whenever Im on the road and heading to cities or states where having a front plate is recommended. I do no street parking at home, so most the time I keep the plate in my frunk.
  12. vandacca
    Hamilton
    Correction. On the Model-S, it's attached by adhesive. On the Model-X, it's screwed in (SC will first drill holes into the bumper). Not sure if Tesla has changed (in past 12 months) or will change the way the license is attached to the Model-X bumper, but that's how it was for me.
  13. boaterva
    They will leave it off on the X if requested. At least my DS has agreed to do so. I've got The Law coming for my car.
  14. Padelford
    Seattle
    I found the supplied allen wrench to be a tight fit in the bolt heads. I'd recommend taking some 220 grit sand paper and do a little, careful sanding on the wrench end flats just to get a couple of mils (1 mil = 0.001") extra clearance in the bolt heads. Don't rotate the wrench while sanding!
  15. DDBD
    DDBD New Member
    Kansas City
    I ordered and installed "The Law" front license plate bracket and found it to be very sturdy but was not comfortable with the plastic grill attachment. It seemed to have a very long lever arm and when going through car washes, I felt that it would put quite a bit of torque on the plastic grill. I didn't want to take a chance on breaking it and having to replace th grill. I then came up with the above addition to add some stability and it seems to be very solid but totally reversible for the future. I took a piece of 2" pvc pipe and cut to the length of the metal crossmember of the bracket-(8") and put a strip of double sided 3M tape along the top and bottom. I then held up the bracket slightly and slid in the pipe and stuck it down to the crossmember above and the bumper lip below. It now holds solid and takes the stress off the plastic grill behind.
  16. skip8jj
    skip8jj Member
    Portland, OR
    Nice installation. We picked up our MX today and I asked the fellow if they would install the front license plate. He was a bit hesitant and the more he hedged and I looked at the front of the X the less willing I was to clutter it with the plates, especially to drill the holes for its installation. He suggested waiting a while and mentioned the Law which I had seen on this thread too. The X front is just too clean and simple. Came home and ordered one the these "Laws".
  17. Gwgan
    Gwgan Almost a wagon
    Maine
    You may have already seen these close-up pics but here they are again Torklift, The Law
    I agree that the wrench provided is too short to avoid marring the plastic, even my screwdriver version was a bit short.
  18. boaterva
    I’ve not installed mine yet (waiting for transfer to be processed, not much point for a paper plate that might blow away!) but tested the Allen wrench in the bolts and it feels like a good fit. That issue may have been solved or could be individual problems on mass produced wrenches.
  19. kpalaniswami
    kpalaniswami Member
    Portland, OR
