(snip)
To feed the 12V from the DC-DC all the time would require the contactors stay closed; not a safe situation. If the contactors are allowed to open, then the architecture requires an external power source (i.e., the 12V battery) to close the contactors to get power to the drive drain when you want to drive the car.
then why wouldn't providing a similar singular link from the 12V power supply provide
exactly the same safety?
the 3G, WiFi and Bluetooth are exactly the same sort of radio as is in my phone, and the keyfob is even lower power. It's able to idle for days on a 5whr LiPo battery, even if I use it for a few minutes a day. so that's probably not it, although they could have foolishly chosen a high power design.
the center console (several processors, not just a cpu) uses more power but again, unless they made a foolish decision, not much more when idling.
If I understand what it is, the battery management system is a relatively simple computer controlling a bunch of big relays. if the design is such that the electricity is fighting a big spring at all times, that might be doing it. it shouldn't be necessary, although they may have chosen an off the shelf contactor for proven reliability. on the scale of a thing that's plugged in, 1-2kwh is not a big drain, but it is a lot for a battery...it's probably more than the entire capacity of the battery.
the thing is, the car should be able to keep this thing topped up by turning on the trickle charger every hour or so. it may be that they have to turn too much of the car "on" to do this frequently and are trying to save power. but if it's plugged into a charger, this shouldn't matter.
