Any recommendations for quieter tires for Model X P90D?
Discussion in 'Model X: Driving Dynamics' started by Blastphemy, Mar 22, 2017.
  1. Blastphemy
    Blastphemy Member
    Los Angeles, CA
    I took our Model X P90D in for its first annual service and was told our rear two tires have a tread depth down to 3, so we need to replace them, soon. Mind you, we only have 17,500 miles on those tires, and we don't drive crazy, so I'm reticent about buying the same tires again and having to replace them again before the lease is up.
    Can anyone recommend an alternative tire, preferably ones that are quieter (i.e., less road noise)? I don't care if I take a mileage hit as long as the new tires reduce the unacceptable road noise this car makes.
    My X has the 20-inch wheels and was one of the first 400 built, but I forgot to check the exact brand/size of the OE tires before posting this thread. (My wife has the car at the moment, so I can't give those specifics yet.)
    Suggestions for both rear and front tires would be appreciated! I have very limited experience and knowledge when it comes to tires, unfortunately :(
    Thank you, community!
  2. McManX
    McManX Member
    San Francisco, CA
    The 20" all season conti silent cross contact (or whatever they are called) seem pretty quiet to me. I think the performance have different tires.
  3. FarmerDave
    FarmerDave Supporting Member
    Martinsburg, PA
    I also have an early P90D and it has the 20" ContiSilent tires that McManX describes. They seem pretty quiet to me, at least on asphalt surfaces.
  4. Dave SB
    Dave SB New Member
    Mercer Island, WA
    You should stay with the Michelin tires for now. Your default setting lowers the X over 55mph. This changes camber and rapidly wears the rear tires. Much more than front.
    Reset Toby "never" under option for adjust suspension height. Ours lasted 19,000 miles.
    Number 495
  5. Blastphemy
    Blastphemy Member
    Los Angeles, CA
    The car's four tires are all Michelin GreenX 220 AA A Latitude Sport 3, 255/45 R 20 in the front and 275/45 R 20 in the back.
    Our car is set to never go below Standard height. Sometimes we raise it in parking lots, but the car won't let us drive in High or Very High above 20-30 mph.
    I wonder if I should buy the ContiSilent tires? Has anyone had a chance to compare those to the Michelins?
  6. ptsagcy
    ptsagcy Member
    NJ
    As I have posted elsewhere, my very early P90D came with Michelin summer tires and they were very noisy. I switched to Conti-Silent all-seasons and they are much quieter. I have 17,000 miles on them with plenty of tread left and no uneven wear.
    • Helpful x 2
  7. Craig-Y
    Craig-Y Member
    Texas
    I traded my Model X P90D with Michelin tires in on a Model X P100D with Continental Silent tires. I was astounded at the difference! Best sound dampening tires I have ever had. They have a foam liner that dampens the road noise but which can complicate tire repairs. Regardless, I love the silent ride!
  8. Mike M
    Mike M Member
    Boulder, CO
    I like our OEM Conti CrossContact LX Sport's (with silent technology).
  9. BigMskiman
    BigMskiman Member
    Pleasanton, CA
    Also, had & have the OEM Conti CrossContact LX Sport's (with silent technology) in two MX's, very happy with quiet ride & handling.
    They're great in the snow also (M+S rated).
  10. Blastphemy
    Blastphemy Member
    Los Angeles, CA
    I can't seem to find the Continental CrossContact LX Sport Silent tires in these sizes at TireRack.com, and my service center doesn't seem to think a 255/45 size exists. Has anyone put Conti-Silents on your Model X in my sizes recently? (Note that I have the 20-inch wheels, not 22-inch.)
  11. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    #11 scottf200, Jul 5, 2017
    I had Continental 265 and 275 on my X. They lasted 30K miles and were at 5/32 when I left on my last roadtrip. I would get them again for sure. I ran my at 45 psi cold which would get to 49/50 when very hot on long highway. Note 50 psi is recommended even in manual when towing. Tires can handle it.
    Model X FAQ Model X FAQ (wiki)
    Q: What tires are on the Model X?
    A: Continental CrossContact LX Sport; Crossover/SUV Touring All-Season; ContiSilent
    Front: 265/45R20 108V XL; UTQG: 480 A A; Tirerack Per Tire: $349.25
    Rear: 275/45R20 110V XL; UTQG: 480 A A; Tirerack Per Tire: $338.25
    Load Index of 108 = 2205 lbs | 1000 kgs
    Load Index of 110 = 2337 lbs | 1060 kgs
    Speed symbol is V for 149 mph max
    265 -- Continental CrossContact LX Sport
    275 -- Continental CrossContact LX Sport
  12. Blastphemy
    Blastphemy Member
    Los Angeles, CA
    Is it optional whether I put 255s or 265s on my front tires? When I check on Tire Rack, it says 265s won't fit a 2016 P90D. My service center also seemed to think I needed to replace same with same (255s in front).
    I can definitely get 275s for the rear, at least.
  13. BigMskiman
    BigMskiman Member
    Pleasanton, CA
    265s are what almost everybody (& I) have on MX front with Cross-Conti
  14. Blastphemy
    Blastphemy Member
    Los Angeles, CA
    Do you (and almost everybody) have a 2016 Model X P90D?
  15. scottf200
    I had 265s on the front of my 2016 X P90D. Tirerack used to show this as being ok
  16. Blastphemy
    Blastphemy Member
    Los Angeles, CA
    My service center will only replace tires with the same size. So the only way for me to get 265s on the front would be to go to a third-party tire installer. But the service center insisted that if I have 255s, I shouldn't put 265s on the front.
    Would sure be nice to get a definitive answer from Tesla!
  17. scottf200
    Remind them that the P90Ds came with 3 types of tires and all different sizes. 2 of 3 were 265s in the frong. Ask them about that? Certainly they were not built differently. From the orig X wiki that I pointed to above.
    Goodyear Eagle F1 Asymmetric 3; Max Performance Summer; SoundComfort Technology
    Front: 265/35R22 102W XL; UTQG: Pending; Tirerack Per Tire: $179.30
    Rear: 285/35R22 106W XL; UTQG: 300 AA A; Tirerack Per Tire: $184.70
    Load Index of 102 = 1874 lbs | 850 kgs
    Load Index of 106 = 2094 lbs | 950 kgs
    Speed symbol is W for 168 mph max
    Michelin Latitude Sport 3
    Front: 255/45R20
    Rear: 275/45R20
  18. BigMskiman
    BigMskiman Member
    Pleasanton, CA
    You can search on it, but my 2016 90D & P100D have them.
  19. mspisars
    mspisars Member
    Charlotte, NC
    #19 mspisars, Jul 5, 2017
  20. scottf200
    Yes, but did you notice the speed rating is lower. I question if the quality of the tire being lower then. ie. can it handle the temps, can it handle the psi for towing or better mileage (higher).
