Any way to disable brakes lights from activating when letting off accelerator?
Discussion in 'Model S: Driving Dynamics' started by keith4909, Feb 6, 2021.
  1. keith4909
    keith4909 Member
    Sf bay
    2014 model s.
  2. spsheridan
    spsheridan Member
    Los Angeles
    Why would you do this? Do you not want folks driving behind you to know that you are decelerating?
  3. thimel
    thimel Member
    Just let off the accelerator a tiny bit so your deceleration is very gradual.
  4. Big Earl
    Big Earl bnkwupt
    Springfield, VA
    No, there isn’t.
  5. keith4909
    keith4909 Member
    Sf bay
    I drive fast and don’t want to tip off police by brake lights.
    • Disagree x 2
  6. MXLRplus
    MXLRplus Active Member
    Eastvale, CA
    Change the regen setting to low?
  7. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    There are regulations that specify that Tesla has to light the brake lights any time you regen past a certain g threshold. So no you can't turn the feature off.
  8. trm2
    trm2 Active Member
    CLE
    You need a manual transmission.
  9. beatle
    beatle Member
    Springfield, VA
    Wire in a disconnect switch to your brake lights so they don't come on at all.
  10. dark cloud
    dark cloud Active Member
    BC
    If the police are behind you then they already know the speed you are going. o_O
  11. David29
    David29 Supporting Member
    DEDHAM, MA
    I don't get it. If you are driving fast, how would brake lights tip off the police? Pardon my ignorance...maybe i do not speed enough!
  12. keith4909
    keith4909 Member
    Sf bay
    Most times I see them before they see me and the brake lights illuminate hence directing them my way
    • Disagree x 2
  13. animorph
    animorph Active Member
    Scottsdale, AZ
    You can hold the parking button down to use it as an emergency brake. I'm not sure if that activates the brake lights or not. You have no way to modulate the braking, so you may be attracting unwanted attention by using them also. Light regen so that the lights don't trigger is probably the best bet.
  14. dark cloud
    BC
    • Funny x 7
  15. garrett5688
    garrett5688 Member
    DFW
    this. And do the same for the headlights and maybe they won’t see you at all. Stealth mode!!
    • Funny x 3
  16. Hayseed_MS
    Hayseed_MS Member
    Midwest
    I can attest it is not due to brake lights. If they are moving, they know your speed relative to their speed. They also are trained to judge speed visually. It is easy to see a vehicle that decelerates relative to the environment and other traffic.
    • Disagree x 1
  17. Doanster1
    Doanster1 Member
    Oregon
    Assuming you’re continuing to be serious here, sounds like you’re doing well over the speed limit so if you see the LEOs before they see you, you’re going to be stomping on the brake pedal anyway. Regen deceleration isn’t going to be enough to save you from that rather quick shot of the radar gun. It doesn’t search out brake lights. It returns a value of a quickly moving object. Illuminated brake lights may just get you a higher fine, that I get.
    LEO: “Subject car was caught on radar at 90mph... WITH full brake lights on so we estimate they were well over 100mph.”
  18. Ciaopec
    Ciaopec Member
    Close to where SpaceXploration begins: 32952
    Ask the guy ahead of you after he slams on the brakes with lights disabled in the same situation. You'll have time to talk while waiting to be pried apart. Be careful what you ask for.
  19. brunla
    brunla Member
    Los Angeles
    Just press the "hover" button and fly away in the opposite direction of the cops.
    (This message is from the future)
    • Funny x 2
  20. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    Mods should delete this thread. Very dangerous what is being suggested here and potentially filled with legal liability.
