Any way to upgrade the dome lights
Discussion in 'Model 3: Interior & Exterior' started by fr100, Apr 6, 2018.
  1. fr100
    fr100 Member
    Northern CA
    They seem rather dim with the black interior.
  2. Haxster
    Haxster Member
    Silicon Valley
  3. fr100
    fr100 Member
    Northern CA
    I don't see any dome lights there. Am I missing it?
  4. Haxster
    Haxster Member
    Silicon Valley
    Looks like it may be a pre-order item.
    www.abstractocean.com/Tesla_interior_light_kit/
    These make a huge difference on the Model S. Hopefully, they'll have these for your M3 soon. Hang in there...
  5. fr100
    fr100 Member
    Northern CA
    I'm looking for the round map lights in the ceiling. Haven't seen any replacements sold anywhere.
  6. tesababa
    tesababa Member
    San Francisco, CA
    I agree those dome/map lights are extremely weak/dim. I would love to see a solution too.
    I don’t think the upgrade lights mentioned above are compatible with the dome lights( they are not mentioned in their charts)
  7. SKRGO
    SKRGO Member
    Planet Earth
    This is the push on push off map light used in the MS. I purchased this from Service for $70.00 USD each. Is this what you are referring to?
  8. flashflooder
    flashflooder Member
    Charlotte, NC
    I've removed the headlight / hazard light assembly in the Model 3, and I don't see an easy way to replace the dome lights. The module is integrated with the car microphone, dome lights, and hazard lights.
    I didn't look too closely, but didn't see an obvious way to detach the dome light portions.
  9. tesababa
    tesababa Member
    San Francisco, CA
    The same location dome lights in MS are much brighter
  10. chojn1
    chojn1 Member
    Sugar Land
    #10 chojn1, Sep 29, 2018
    Alternate solution? Console light placed under the screen mount. Activated by opening and closing the middle console compartment. Less distracting than a bright dome light, and no glare on the screen.
    • Informative x 2
  11. Brenzo
    Brenzo Member
    Chicago, IL
    So @chojn1 ... you're just going to drop that video there and not provide any more details on how you configured that awesome setup... o_O
  12. chojn1
    chojn1 Member
    Sugar Land
    Sorry about that. Was not sure if anyone was interested.
    Open the right side of the center console.
    There is a two wire (brown and white) plug which connects the LED from inside the middle center console to 12v.
    Unplug this, and plug in your own 12v LED. The plug/connector is the same one used in all the interior LED's.
    Attach that LED to the underside of the display mount.
    The lid open/close sensor is not wired in line with this power line, so you're good to go.
    This is the LED strip and connector I used for the trunk. You only need a strip of 3 LED for this purpose.
    • Helpful x 2
    • Love x 2
  13. knarf
    knarf Member
    NorCal
    Where did you get the LED connector from? I'd like to avoid cutting any internal wires and make a splitter for both center console and phone area lighting. Thanks!
  14. chojn1
    chojn1 Member
    Sugar Land
    • Informative x 2
  15. EerieP
    EerieP Member
    Seattle
    Wouldn't this solution mean we would lose lighting in the center console though?
  16. chojn1
    chojn1 Member
    Sugar Land
    You could tap the line and keep both lights (the oem recessed light in the bin in addition to the new light from under the display). After testing with both lights, I found the recessed light to be unnecessary and a waste of energy given the relative brightness of the new LEDs.
    • Informative x 2
  17. SemoTech
    SemoTech Member
    Hackensack, NJ
    Thanks @chojn1 very helpful.
    For anyone that wants to just buy it pre-made, MyMod3.com has it for sale for about $20+shipping HERE
  18. XLR82XS
    XLR82XS D M C
    SWFL | Vegas
    @chojn1 I just ordered your console light.
  19. ftenab
    ftenab New Member
    Spain
    Hi sir, is the red/black wire visible on the short way to the underside display final position or there is any way for hiding?? Many thanks
  20. SemoTech
    SemoTech Member
    Hackensack, NJ
    @ftenab No, it is not visible unless you look very closely from the side right by the dash. You could always do what I did and paint the wire black 1st.
