Anybody have a Front Lip spoiler?
Discussion in 'Model 3' started by skrtskrt, Aug 1, 2019.
  1. T3SLAROD
    T3SLAROD Member
    SoCal
    #161 T3SLAROD, May 22, 2020
  2. 1FASTROD
    1FASTROD Member
    Toronto
    I'm liking the lip so far. It feels subtle but slightly aggressive to me. Purely cosmetic but I think Tesla should have distinguished the Performance M3's from normal M3's, and this helps my car stand out.
    Will try to get pics of the screws but it's low on the front. I had to lift up the front to install it and may need to do that for pics.
  3. jookyone
    jookyone Member
    Mountains
    The more subtle front lip from China (3 piece "carbon-fiber-esque") arrived. Here's pictures of it fitted up temporarily with double sided tape with a mild attention to alignment. Tried to take pictures similar to the angles of the more aggressive lip in this post.
    Not sure which one I am going to put on. If I do put one on, I will definitely have it wrapped, it's too shiny and CF lines are warped on the left side (last pic).
    IMG_20200526_171944.jpg IMG_20200526_172011.jpg IMG_20200526_172033.jpg IMG_20200526_172104.jpg
  4. Rothgarr
    Rothgarr Member
    United States
    I have the same problem with mine on the passenger side piece where the CF pattern is laughably bad. I asked the seller if they are all like that of if they can send me one that's less noticeable. No way I can put it on the car as-is.
  5. Rothgarr
    Rothgarr Member
    United States
    Can you please link to that spoiler you purchased?
    They have carbon fiber wraps, but I wonder if it would have the same problem with distortion about the complex shapes of some of these spoilers.
  6. 1FASTROD
    1FASTROD Member
    Toronto
    I would think they are all like that because of the complex curves with the edge wings and the process the carbon look is applied (hydro-dipped). I ordered gloss black for this reason alone. I find if you want carbon look it looks good only for mostly flat pieces, and your best bet is to get a real carbon fiber product instead.
    Wrapping the front lip may be a good option (still has sharp curve at wing) as-is plasti-dipping it or painting. Still I think Jookyone's install looks good and I'd just keep it until it can be painted/wrapped.
  7. jookyone
    jookyone Member
    Mountains
    More subtle lip which I did install:
    For 2016-2019 Tesla Model 3 Sedan Carbon Fiber Style Front Bumper Lip Spoiler | eBay
    More aggressive lip:
    Carbon Fiber Look Style Front Bumper Lip Body Kit Spoiler For 16-19 Tesla Model3 | eBay
    I'm not completely confident in the screws included with the more subtle lip (and lack of adhesive tape included with the aggressive one, but I applied some of my own), so I will be upgrading those. The quality of the subtle lip was lower than the aggressive, and also had fewer screw holes, all of which I was able to mount in the black part of the bumper. I also had a friend see if the lip was flopping around at speed. It wasn't (I assumed attention to mounting makes a difference). I also did a 25 mile loop with an attempt to determine range effect at similar speeds, before and after mounting (max speed was 70mph). A negligible change in Wh/mile ( 243 vs 245) likely due to not being a robot :) hope this helps.
    • Informative x 2
  8. 1FASTROD
    1FASTROD Member
    Toronto
    Thanks for the testing.
    Was able to test the subtle wing to ~170 (105 MPH). Don't blame me blame a local Huracan, lol.
    Still holding strong with simple screws and adhesive (3m tape).
  9. Rothgarr
    Rothgarr Member
    United States
    Thanks. The one I have has the smaller "wings" at the end (not sure what they are called). You think the one with the larger wings is the more subtle one?
    But the pattern is so bad on one of the pieces I got I have to return it and the seller is being a pain about it.
  10. Murattukaalai
    Murattukaalai Member
    Denver
  11. turnto643
    turnto643 Member
    @Khoa5462 How has the IKON front lip held up and have you noticed any efficiency gains? Asking because I'm thinking about ordering the IKON lip painted to match my car.
  12. Electromonkey
    Electromonkey Member
    Dallas
  13. Murattukaalai
    Denver
    Maxton should have made OEM replacement not something that sticks over OEM diffuser
  14. T3SLAROD
    T3SLAROD Member
    SoCal
    For those wanting the Maxton Kit, contact Maxton USA. The entire kit is less than $1K in glossy black. They are getting their shipment in July.
  15. larry996
    larry996 Member
    Atlanta
    I installed the "Carbon Look" front spoiler like many on here. Unfortunately, I was driving this past weekend and following closely behind a truck when he struck a groundhog. Yup, I had no time to react. This spoiler is low and did scrub with UP lowering springs I'm going to look into Maxton Design V1. It only adds an inch or two. This spoiler was over 3.5 inches in the front
  16. Dilpickle
    Dilpickle Member
    Fresno, CA
    @Anyone who has the 3piece carbon fiber spoiler from eBay, I know you have to screw it in. I am wondering are you screwing into the actual bumper or just the undercarriage part, so if the time come to remove it like this individuals who got struck by a groundhog, will it leave holes ??
  17. 5abi
    5abi Member
    Vancouver
    i think these cheap $62 lips look better then then the more expensive ones lol. The second link doesn’t work anymore. Do you recall vendor name or see another listed for same price? Thank you
  18. Mash
    Mash Supporting Member
    Prague
    As long as you don't care about whacking out carefully designed OEM aerodynamics, you can certainly go cheap.
  19. Rothgarr
    Rothgarr Member
    United States
    I can't believe someone would consider putting those cheap three-piece things on such a nice car, especially with that "dipped carbon fiber" finish that looks like it was printed on silly putty and stretched in ungodly ways so that the pattern is totally distorted near the wing tips.
  20. 5abi
    5abi Member
    Vancouver
    I like it. $62 and 30 mins of your time it’s a no brainer for me
