Anybody know how to removed the visors?
Discussion in 'Model S: Interior & Exterior' started by artsci, Feb 22, 2014.
  1. artsci
    artsci Sponsor
    Timonium, Maryland
    [FONT=American Typewriter, sans-serif]Who knows how to remove the visors? I need to remove the passenger side visor. I checked it out this morning but didn’t see an obvious way to do it that didn’t risk some damage to the headliner. Any advice would be much appreciated.[/FONT]
  2. JPP
    JPP Active Member
    SF Bay Area, CA
    ...it's been done before to get Elon to sign one at Teslive....hopefully someone will post how...
  3. EdA
    EdA Model S P-2540
    Massachusetts
    I'd say ask artsci, oops...
  4. artsci
    artsci Sponsor
    Timonium, Maryland
    :) It's now become a moot point. I want to remove the visor to send it to Oznium in Hong Kong for their work on the lighted visor design. But nkohlimd beat me to the punch and just picked up a set from his local SC.
  5. EdA
    EdA Model S P-2540
    Massachusetts
    He was my 2nd choice (and practically my neighbor!) and figured you'd already tried him...
  6. nkohlimd
    nkohlimd Member
    Natick, MA, United States
    Ed......Thanks for the shoutout and the vote of confidence....
  7. Bsweasel1
    Bsweasel1 Member
    houston
    does any have instructions on how to remove the drivers side visor? Going to the Austin Capital Tesla rally and Elon is going to be there. Wanted to get him to sign my visor. Thanks in advance.
  8. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    It's quite easy:
    1. Using a spudger, carefully pry the wrap around trim piece that wraps from the outboard side of the visor around where the arm goes into the headliner. Be careful. It looks like the interior semi-circle that wraps around the arm should loosen, but it does not. You can flex the trim piece enough to unhook the small tabs that lock it to the foundation of the mount. It will then drop away.
    2. Unscrew the one screw in the anchor located on the windscreen side
    3. Gently and easily ease the entire visor assy down and out. There is a fairly large flange that tucks up under the headliner on the inboard side to complement the screw's holding and locating role.
    4. You are done! Simply reverse to reinstall.
    After I figured out the first one, the second one approx 1 min to remove.
    Have fun!
  9. Bsweasel1
    Bsweasel1 Member
    houston
    thank you so much
  10. CHG-ON
    My sister calls my obsessive penchant for disassembling my cars "car bonding".
  11. Bsweasel1
    Bsweasel1 Member
    houston
    Thanks for your reply. I cracked the cover while taking it off. I did get my visor signed by Elon today. Success!
