Sig P85
44718 miles
March 13, 2015
( Abbreviated: )
44718 miles
March 13, 2015
( Abbreviated: )
2Performed four wheel alignment as requested.
3Perform courtesy inspection.
(various details unrelated to this thread)
4Concern: Client reports persistent rust on brake rotor hats.
Correction: Brakes Discs & Calipers General Diagnosis
Inspected and verified excessive corrosion on brake rotor hats. Updated parts now available to address this concern.
Corrections: Brake Rotors - Front - Set
Replaced the front brake rotors with updated units as needed.
FRONT BRAKE ROTOR WITH AS-CAST OUTER HAT (1025099-00-B)
Corrections: Brake Rotors - Rear - Set
Replaced the rear brake rotors with updated units as needed.
REAR BRAKE ROTOR - OUTER HAT AS CAST (6006431-00-D)
Concern: Technician notes that front brake pads are worn to 2mm, recommends replacement.
Corrections: Brake Pads - Front - Set
Found front brake pads to be worn to minimum thickness during rotor replacement. Replaced brake pads.
FRONT BRAKE PAD AND NOISE SHIM KIT (6006429-00-B)
