ANYONE CAN GET ME THESE PARTS??
Discussion in 'Tesla Parts for Sale' started by nexandy, Apr 12, 2017.
  1. nexandy
    nexandy New Member
    torrance
    I'M NOT GOING TO SERVICE CENTER. I NEED PARTS ONLY.
    2013 TESLA MODEL S
    1 6006417-00-C FRONT SUB-FRAME ASSY 1 ea
    2 6006417-00-G FRONT SUB-FRAME ASSY 1 ea
    3 2007111 BOLT 2 ea
    4 6008489-00-B LH BRACE 1 ea
    5 6008490-00-A RH BRACE 1 ea
    6 1006809-00-A BOLT 2 ea
    7 2007069 BOLT 2 ea
    8 1009169-00-A BOLT 4 ea
    9 1013184-00-D LH FRT KNUCKLE 1 ea
    10 1013182-00-D RH FRT KNUCKLE 1 ea
    11 1027121-00-A FRONT HUB ASSY 2 ea
    12 2007114 BOLT 8 ea
    13 2007065 LUG NUT 10 ea
    14 6006532-00-A LH UPPER CONTROL ARM 1 ea
    15 6008930-00-A RH UPPER CONTROL ARM 1 ea
    16 1004357-00-A BOLT 1 ea
    17 2007059-00-B NUT 1 ea
    18 1004350-00-A BOLT 1 ea
    19 1004351-00-A NUT 1 ea
    20 6007998-00-C LH FORE LINK 1 ea
    21 6006664-00-C RH FORE LINK 1 ea
    22 2007108 BOLT 2 ea
    23 2007115 WASHER 2 ea
    24 1006484-00-A NUT 4 ea
    25 1004358-00-C NUT 4 ea
    26 1048951-00-B AFT LINK 2 ea
    27 2007106 BOLT 2 ea
    28 2007107 WASHER 2 ea
    29 1033093-00-A WASHER 4 ea
    30 6007084-00-D FRT STABILIZER BAR 1 ea
    31 2007069 BOLT 4 ea
    32 6007098-00-A LH LINK 1 ea
    33 6008915-00-A RH LINK 1 ea
    34 2007090-00-C NUT 4 ea
    35 6006351-00-C FRONT AIR SPRING 2 ea
    36 1008614-00-C BOLT 2 ea
    37 2007073 NUT 2 ea
    38 6006972-00-A STEERING GEAR ASSY 1 ea
    39 1051424-00-A BOLT 1 ea
    40 6007071-00-A OUTER TIE ROD 2 ea
    41 2007102 NUT 2 ea
    42 1004356-00-B NUT 2 ea
    43 1013033-00-A STEERING COLUMN ASSY 1 ea
    44 2007100 BOLT 1 ea
    45 2007099 BOLT 2 ea
    46 6006939-98-B UPPER LINK 1 ea
    47 2007098 BOLT 1 ea
    48 2007103 BOLT 1 ea
    49 1006883-00-A NUT 1 ea
    50 6006950-00-B SEAL 1 ea
    51 6008763-00-A LOWER LINK 1 ea
    52 1003160-00-D LH FRT CALIPER 1 ea
    53 1003161-00-D RH FRT CALIPER 1 ea
    54 2007068-00-B BOLT 4 ea
    55 1055066-00-B FRONT PAD 1 ea
    56 1025099-00-B FRONT DISC ROTOR 2 ea
    57 1004377-00-B BOLT 2 ea
    58 1027661-00-B LH SHIELD 1 ea
    59 1027662-00-B RH SHIELD 1 ea
    61 6007012-00-F REAR SUB-FRAME 1 ea
    62 6007023-00-B LH REAR KNUCKLE 1 ea
    63 1042506-00-A LH REAR KNUCKLE 1 ea
    64 6007024-00-B RH REAR KNUCKLE 1 ea
    65 1042507-00-A RH REAR KNUCKLE 1 ea
    66 1027170-00-A HUB ASSY 2 ea
    67 2007066 BOLT 8 ea
    68 2007065 LUG NUT 10 ea
    69 1021416-00-A LOWER CONTROL ARM 2 ea
    70 2007075 BOLT 4 ea
    71 2007076 NUT 10 ea
    72 1056323-00-A BOLT 2 ea
    73 2007073 NUT 2 ea
    74 6006895-00-A INTEGRAL LINK 2 ea
    75 7007078 BOLT 6 ea
    76 6006840-00-B TOE LINK 2 ea
    77 2007061 BOLT 2 ea
    78 2007089 NUT 2 ea
    79 2007062 WASHER 2 ea
    80 2007064 BOLT 2 ea
    81 1043053-00-A BOLT 2 ea
    82 2007063 NUT 2 ea
    83 2007077 WASHER 2 ea
    84 1021418-00-C UPPER LINK 2 ea
    85 6007092-00-B REAR STABILIZER BAR 1 ea
    86 2007116 BOLT 2 ea
    87 6007100-00-A LINK 2 ea
    88 2007090-00-C NUT 4 ea
    89 1007719-01-B REAR AXLE 1 ea
    90 1020297-00-A NUT 1 ea
    91 6006434-00-C LH REAR CALIPER 1 ea
    92 6006434-00-C RH REAR CALIPER 1 ea
    93 6006438-00-C BOLT 4 ea
    94 2007068-00-B REAR PAD 1 ea
    95 1055068-00-B REAR DISC ROTOR 2 ea
    96 1004377-00-B BOLT 2 ea
    97 6006432-00-A LH SPLASH SHIELD 1 ea
    98 6006433-00-A RH SPLASH SHIELD 1 ea
    99 2007067 BOLT 6 ea
    100 6008142-00-A SPRING & PIN KIT 2 ea
    101 6006352-00-C LH REAR AIR SPRING 1 ea
    102 6006353-00-C RH REAR AIR SPRING 1 ea
    103 1008339-00-C BOLT 2 ea
    104 2007073 NUT 2 ea
    105 1054042-00-A WHEEL SOPRT GRAY 4 ea
    106 6005879-01-A CENTER CAP 4 ea
    107 1034602*-00-B TPMS 4 ea
  2. lunitiks
    lunitiks ˭ ˭ ʽʽʽʽʽʽʽʽʽ ʭ ʼʼʼʼʼʼʼʼʼ ˭ ˭
    Prawn Island, VC
    Oh, just those parts
    • Funny x 7
  3. RichardD
    RichardD Supporting Member
    Texas
    Are you building a car from the ground up?
  4. MileHighMotoring
    Parker, CO
    Find out the local Tesla-approved body shop and work with them to get the parts. Or, go to the Service Center (which you mentioned you won't do). Those are your only two options.
  5. Qurix
    Qurix Member
    Poland
    Hi I have one crashed tesla for parts. Please send photos of that what you need at [email protected]
    Best Regards
  6. nexandy
    nexandy New Member
    torrance
    How come they don't sell them without real car? Nobody sell the parts only?
  7. satoshi
    satoshi Electrical Engineering Student
    United States
    I have one of these sitting around. I bought it to replace the knuckle on my salvage when I was still going to attempt to repair it.
    Since I've decided to part-out instead, you can have it at the same price I paid for it.
    Message me for details.
