Anyone DIY a heater for the front radar?
Discussion in 'Technical' started by Murph85, Dec 10, 2017.
Tags:
  1. Murph85
    Murph85 Member
    Maryland, USA
    As we all know the 'new' bumper shields the front radar better from snow, however it can still build up over the radar. Has anyone added a heater to the front to prevent this for long roadtrips?
    I was thinking about it and I don't think it would be super difficult. Obviously a metal plate would be counter productive, however if it was a mesh was < 1/10th of the wavelength of the radar it shouldn't be a faradaycage, however I am not sure how much of an impact it would have. Just some quick math. 77Ghz = 3.8mm wavelength, and a quick search shows for a faradaycage 1/10 to 1/20th of the wavelength is required, so it looks like you'd have to have a pretty fine mesh for it to completely block the radar.
    Idea #1, wirewound silicone mat
    Silicone Rubber Heater, wire wound, 5" x 5", 125 watts, 120v, 5 w/sq. in, 8" leads
    Pros: super easy, just need to glue it to the bumper in front of the radar
    Cons: might degrade the radar
    Idea #2, IR heater
    5 inch Infrared Strip Heater, 500W
    Pros: won't mess with the radar
    Cons: way too expensive
    Idea #3, long heated strip along the top of othe bumper
    Pros: not in the way of radar
    Cons: it would only work if the melted snow above the radar was enough to come down and melt the snow building up in front of the radar.
    Idea #4, duct in warm air to heat the bumper from behind
    Pros: no interferance
    Cons: more complicated, will probably use a lot of power (compaired to just the headed pad)
    Has anyone already solved this problem? Does anyone know about a type of heated pad that is RF transparent? I see some pads that use kapton, however it looks like that is just the material used around metal wires.
  2. lunitiks
    lunitiks Cool James & Black Teacher
    Prawn Island, VC
    Checked clearance between radar and bumper?
  3. arnis
    arnis Member
    Estonia
    MASSIVE!
    Ideas 1 and 2 are unappropriate. We need 12V heating element. Something like 10-30W. Not 125 nor 500:D:D
    I think there are heating elements that do not act as faraday cage. Something not metallic. Maybe carbon based.
  4. Murph85
    Murph85 Member
    Maryland, USA
    I saw that there are some plastics that conduct heat like this: https://www.celanese.com/coolpoly I was also thinking that even something that doesn't mess with the radar much it might mess up a calibration built into the sensor.
    i looked at the clearance and since it is so large the heated pad would have to be pretty big. I am liking the IR leds projecting light forward, i need to do some more research trying to find some good hardware and see if I can just 3d print a bracket. However I am not sure what the power requirements will be.
  5. outdoors
    outdoors Always roaming
    off grid till Xmas
    Elon tweet-
    Long-term, the Tesla car will work purely on vision, with radar just a plus, but maybe worth adding a radar heater anyway-tweet
